Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
2015 F250 Lariat diesel PSD with 3.31 RAR
Old 01-08-2016, 11:05 AM
Paulcal
Paulcal is offline
Paulcal is starting off with a positive reputation.
HI all
Looking at buying this truck but it has the 3.31 rear end. How's that gonna work towing a 9200 lb fiver dry weight well over 10k loaded. Hitch weight is 1600 lbs.
What are the limitations.
Have only experience with a 3.73 rear end
Thanks
Paul
Old 01-08-2016, 11:09 AM
suzuki0702's Avatar
suzuki0702
suzuki0702 is offline
suzuki0702 is starting off with a positive reputation.
Will tow it like a dream. You can get 3.31, or 3.55 gears come on the 20" wheel equipped truck IIRC
Old 01-08-2016, 11:26 AM
radium
radium is offline
radium is gaining momentum as a positive member of FTE.radium is gaining momentum as a positive member of FTE.
i have same gears 2016 6.7 f 350 pulled duel axle well over ten thousand pounds did not know it was back their plus you will love mileage
Old 01-08-2016, 12:45 PM
my_crib_too's Avatar
my_crib_too
my_crib_too is online now
my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.
Originally Posted by Paulcal View Post
HI all
Thanks
Paul
Welcome to FTE!!!!
Old 01-08-2016, 01:40 PM
roadrunner01
roadrunner01 is offline
roadrunner01 is gaining momentum as a positive member of FTE.roadrunner01 is gaining momentum as a positive member of FTE.
My '15 has 3.31 rear, I currently have 30,000 mi., trouble-free. Towing will be no issue with all of the ponies under the hood. I have a 12,000 gvw trailer that I tow, no problems as I could go 90 mph if I so desired.
I ordered my truck with the equipment I wanted, including the 3.31 rear end/18" wheels, you won't be disappointed.
Old 01-08-2016, 01:51 PM
2civicrr
2civicrr is offline
2civicrr is gaining momentum as a positive member of FTE.2civicrr is gaining momentum as a positive member of FTE.
Compared to my 2004 6.0 with 4:11 running an aggressive tow tune, the 6.7 is worlds better in power, braking and comfort. Seriously, it isn't even close.
Old 01-08-2016, 04:59 PM
CascadeF250's Avatar
CascadeF250
CascadeF250 is offline
CascadeF250 is gaining momentum as a positive member of FTE.
I have a 2011 with that same gearing. I regularly pull over 10,000 pounds with it. I have 3:31 gears and 18 inch tires and it pulls just great. I get decent good mileage empty also.
Old 01-10-2016, 04:25 PM
FDNY13's Avatar
FDNY13
FDNY13 is offline
FDNY13 is starting off with a positive reputation.
Here's the link to the towing capacities of the 2015's: http://www.ford.com/resources/ford/g...tyPU_Sep30.pdf
As you can see, there's no difference in tow rating between the 3:31 and 3:55. When I spec'd-out and built/ordered my 2015 last year I chose the 3:31 with 18" wheels and couldn't be more satisfied towing my 14K 5'ver...and also the SOLO fuel economy. So bottom line is... don't be deterred by the 3:31 if the rest of the truck is to your liking! Good luck.
Joe
Old 01-11-2016, 12:56 PM
troverman's Avatar
troverman
troverman is offline
troverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud of
I have 3.55 gears on my 18" wheels. I believe you can select it as an option on any of the SRW trucks...maybe it is required with the 20" wheels.
I think the 3.31 will be fine. This engine is very strong.
Old 01-11-2016, 02:08 PM
22rimfire
22rimfire is offline
22rimfire is gaining momentum as a positive member of FTE.22rimfire is gaining momentum as a positive member of FTE.
Camper, or snow plow pkg gets you the 3:55's. mine has the camper pkg with 18" wheels with 3:55's. I agree with everyone so far, you wouldn't even know the difference. Will tow your trailer like a dream.
Old 01-11-2016, 02:15 PM
troverman's Avatar
troverman
Very interesting, thanks for the info. Mine does have the snowplow package, as many of these New England ordered trucks have. A measly $85 gets you stiffer front springs, a higher output alternator, and apparently the 3.55 gears. Still had to pay the $390 for the locking rear end...worth every penny.
Old 01-12-2016, 04:01 PM
superrangerman2002's Avatar
superrangerman2002
superrangerman2002 is offline
superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.
Not even beginning to push the limits of the truck with 3.31s.
10k lbs.... Pfft not even warming up yet.
Old 01-12-2016, 05:50 PM
dmags
dmags is offline
dmags is gaining momentum as a positive member of FTE.
my 2011 had 3.31 and 17" wheels
It pulled great and fuel mileage was better than my 14' with 3.55 and 18" wheels.
@ 80 mph tach was just at 2000 rpm
I would definitely get 3.31 gears again
Old 03-16-2016, 06:08 PM
boomer85
boomer85 is offline
boomer85 is starting off with a positive reputation.
What kind of milage empty do you guys get with the 3.31s? Also tow about the same weight as the OP and found a great deal on a similar truck. Looking to get out of my f150 and get into a 350 for payload , handling, and ease of towing my TT
Old 03-16-2016, 06:29 PM
roadrunner01
With 4 guys and 2,000-4,000 lbs. in the bed I can consistently get 18-20 mpg, but my use is 150 highway, then 8 hrs later 150 highway. Still not bad as I'm 4wd.
Quick Reply: 2015 F250 Lariat diesel PSD with 3.31 RAR
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
