2 piece FE flexplate????
Old Oct 18, 2010 | 10:09 AM
Moto Mel's Avatar
Moto Mel
All of the industrial or marine applications that I have seen had a heavy flywheel and almost all of the time what ever the engine was to power was driven off the crankshaft snout. The flywheel was mainly there to produce and maintain the centrifugal force that was needed to maintain rpm when a load was applied to the engine. And, of course, for a place for the starter to engage the ring gear.
Old Oct 18, 2010 | 11:29 AM
tater_51's Avatar
tater_51
cleaned the parts up, only thing I could find was the ford logo and a 0 stamped on the outer and inner rings, apparently for alignment. Could they have been color coded?? There is a dab of dark blue paint on the outer ring and also some spray (opposite side of paint dab, outer ring) but that could maybe have been overspray?? This came off a 428 so it would have been an externally balanced plate, if that helps at all??
Old Oct 18, 2010 | 11:54 AM
Moto Mel's Avatar
Moto Mel
The early 428s were internally balanced unless you find a offset weight cast into the dampener and another on the flexplate which would prove that it is an externally balanced engine. I don't recall seeing any weight added in the pics posted.
Going back to double check now.
Old Oct 18, 2010 | 11:58 AM
Moto Mel's Avatar
Moto Mel
It is an internally balanced engine. Pre CJ and SCJ and an excellent find! It has the right crank for a lo buck 427 stroker.
Old Oct 18, 2010 | 12:45 PM
tater_51's Avatar
tater_51
Learning something everyday! The outer ring has no weight added but has had some removed, via drill. It weighs about 3 times as much as the other 428/410 flexplate I have which i believe is the more common one found on 410/428's. Also two places on the front damper that has been drilled. All I can tell you about the crank is that it's stamped 1U. Bore is 413 and it has the 428 cast inside the center water jackets.
Old Oct 19, 2010 | 06:46 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Another one for the record books... I had heard about the two-piece flexplate somewhere before.
332-428 Ford FE Engine Forum: Heres a pic of a 2-piece cast iron flexplate on a 428.
danlee
Aug 8, 2012 06:53 PM
tlfrantz
Large Truck
Mar 17, 2011 12:31 AM
jle70
Nov 14, 2009 02:06 PM
pg409
Oct 24, 2005 08:12 PM
merc62
Apr 3, 2004 09:54 PM
