Sponsored by: Real Truck
Need diff help
Old Oct 14, 2010 | 09:05 PM
Anomic's Avatar
Anomic
Need diff help
Open, lsd, locker, tru trac etc front and rear, rear only et al
How expensive is it to install this stuff? Parts plus labor to put a tru trac in a f250 standard rear axle (not lsd)
I have no idea about any of this. Anyone know of a good resource that explains it
Old Oct 14, 2010 | 10:34 PM
redford's Avatar
redford
FTE Leadership Emeritus
Maybe this will help?
Randy's Ring & Pinion. FAQ.
Old Oct 15, 2010 | 02:15 AM
wallz's Avatar
wallz
I had a true trac put in last yr. Granted we pay more up here in the Canadian north for everything, but it cost around $250 for the install. I provided the parts, and even replaced all the bearings in there while it was apart so that will add up a little Figured on an 02, it best to replace while everything was apart. The true trac should run you $600-$700 on its own, plus the oil, bearings, shim kit, and install. I also added the 08 alum diff cover at the time.
Exit 295
Jan 6, 2013 07:42 PM
stephen.south
Feb 11, 2010 08:20 PM
TankNeverEmpty
Aug 26, 2009 06:43 PM
Level2
1983 - 2012 Ranger & B-Series
Sep 24, 2007 01:02 PM
wendell borror
16
Mar 25, 2006 08:19 AM
