C6 transmission swap ?'s
I am needing to swap out a c6 in my 78 f250 4x4 with a 429. the c6 in it now has 3rd out of it, but 1st 2nd and reverse are still. good is there an easier way maybe a cheaper way to fix that aside from replacing the transmission? or do you just have to swap it out? if so will any c6 do or does it have to be specific for that vehicle.
Do you know a reputable shop that can either rebuild it or send you to a good rebuilder? $500 maybe????
A replacement trans will have to come from 4x4 with a 460--you can't easily convert a 2wd trans, and the C6 has in integral bell with the pattern for each engine series, so you can't pull one from behind anything but a 385 series, or a 400/351m.
ok so another c6 from a 4x4 would have to used if i wanted a straight up drop and bolt up type deal. but the budget i am on dos not allow me to have someone rebuild it for me. is it something that i can do myself? the kit is only 120 from napa and is called a master kit. not sure if that has the stuff i need to fix the problem.
Get a good book too.
Don't know if this one is any good, but for less than 20$ it might be a help
Amazon.com: Ford Automatic Transmission Overhaul Manual: Models Covered: C3, C4, C5, C6 and AOD Rear Wheel Drive Transmissions, ATX (Haynes Manuals) (9781563924248): John Haynes: Books
quantalimo
08-01-2007 08:44 PM
1979meangreen
08-02-2004 09:08 AM
