HELP - V10 won't start...
Old Oct 14, 2010 | 08:25 AM
neveroddoreven's Avatar
neveroddoreven
I have a 2000 Ex (2WD) with the V10. It sat for about 8 months without being started. I got a new battery, changed the cable ends and replaced the plugs. The thing still will not start. It turns over just fine but never starts up.
Is there anything with the computer or the alarm system that could be causing the problem with the battery being dead for that long? Or maybe something else I am missing?
Old Oct 14, 2010 | 08:38 AM
TYZ78F150's Avatar
TYZ78F150
Did it sit in a moist environment? Maybe try checking connections to say crank sensor, cam sensor. Try checking fuses under dash, and under hood. If it ran when it was parked, it's gotta run now. Hate to sound like a smartass, but is there gas in it? Could possibly be gummed up fuel lines. Try pulling the fuel filter and turning the key to see if fuel squirts out. Place a rag or two under there to catch the fuel. Let us know. Maybe when the battery died it reset the alarm system or something in the PATS syatem or GEM.
Old Oct 14, 2010 | 08:42 AM
neveroddoreven
It did run when it was parked. It's just been sitting outside in hot, humid Houston, TX weather. I checked the fuses under the dash, they all looked good. Will check the ones under hood too. Yes there is gas in it, about 5 gallons. I pulled the fuel filter last night but did not try to start it, I will try that tonight too.
Old Oct 14, 2010 | 08:50 AM
TYZ78F150's Avatar
TYZ78F150
yeah that will tell if there's fuel getting to the engine or not. Also check the pump cutoff switch in the pass. kick panel.
Old Oct 16, 2010 | 10:13 AM
neveroddoreven
Ok looks like the fuel pump is not powering up. Seems weird that it would just stop working while it has been sitting in the driveway. Any ideas?
I did check the fuel cutoff switch and was not tripped
Old Oct 16, 2010 | 12:32 PM
neveroddoreven
Ok hooked up a fuel pressure gauge and there is zero pressure.
Old Oct 16, 2010 | 01:19 PM
Shepherd2's Avatar
Shepherd2
Give the fuel tank a few good wacks, alot of times it'll get you going.
Old Oct 16, 2010 | 04:49 PM
neveroddoreven
Interesting approach. Is there a special "fuel tank wacker" I need to buy or just any regular stick? :-)
Old Oct 16, 2010 | 08:00 PM
Shepherd2's Avatar
Shepherd2
Just use a big rubber mallet. You might have to go a few rounds because of the skid plate.
Old Oct 17, 2010 | 02:35 PM
TYZ78F150's Avatar
TYZ78F150
I've done this on different vehicles before. Sometimes it just gives the pump a little jumpstart if you're lucky.
Old Oct 18, 2010 | 07:58 AM
neveroddoreven
I am going to drop the tank and replace the fuel pump. this is not my primary vehicle so I can take my time doing the R n R. Is there a tech procedure anywhere that documents the process?
jawdoc
Jul 18, 2015 10:25 AM
Papas66
Apr 1, 2014 01:04 PM
psdendurance
Nov 15, 2012 04:44 PM
theenforcer
18
Aug 18, 2012 10:44 PM
Swagtastic
Dec 21, 2011 09:14 PM
