injector pump interchange
Old Oct 12, 2010 | 09:52 PM
fast70's Avatar
fast70
can i use any 6.9 or 7.3 injector pump on my 93 or dose it have to be from the same year i thought they were all pretty much the same
Old Oct 12, 2010 | 11:23 PM
farmert's Avatar
farmert
The 6.9 and 7.3 pumps will interchange. The only thing is they may not be caliberated right.
Old Oct 13, 2010 | 12:35 AM
oreocreaming's Avatar
oreocreaming
best thing to do is after you swap it, time it by ear then take it down to a shop and have it timed right.
Old Oct 13, 2010 | 07:56 AM
fast70's Avatar
fast70
So only thing is timing is there a better year to use what about from a Turbo truck mine is non turbo
Old Oct 13, 2010 | 07:58 AM
johnboggs21's Avatar
johnboggs21
The only difference might be that a turbo pump will have the torque screw on it, but it works just fine in N/A applications.
Old Oct 13, 2010 | 08:02 AM
fast70's Avatar
fast70
Thanks guys I'm trying to get one and get my truck going again I found rebuild kits for the pump for $28 wonder how hard that would be
Old Oct 13, 2010 | 09:02 AM
rodneywar's Avatar
rodneywar
with out a manual it will be very hard and do you have a pump calibrator
Old Oct 13, 2010 | 09:34 AM
fast70's Avatar
fast70
I can get bolth I just need to know what I would need good rebuilds cost alot
Old Oct 13, 2010 | 11:48 AM
wreckinball's Avatar
wreckinball
on this subject, the only difference online that i see is the transmission. Could you just bolt the vacuum regulator valve for the C6 onto any injection pump? I would imagine they are built the same.
1985L8000cat3208
Feb 19, 2016 08:31 AM
Philip Holwell
13
Jan 28, 2013 08:52 PM
1983/84f350
Mar 22, 2012 08:15 AM
mudkicker715
18
May 18, 2009 09:33 PM
myddad
16
Feb 1, 2007 02:49 PM
