i have a 97 7.3 psd and it wont start. I replaced the cps, icp changed the oil, and pulled the driver side valve cover and checked the harness (havent had the chance to check the pass side) its gettin fuel to the top of the motor and i can smell raw fuel coming out of the tail pipe y wont it start?
Check the Glow Plugs, my truck wouldn't start when my Glow Plugs went bad. I believe yours are under the valve covers since its the powerstroke, sounds silly but that can cause it
KAM is the keep alive memory...you need to reset it every time you change a sensor (I do anyways) just pull the positive cable off the battery for around 15 minutes then hook it back up and give it a shot.
