help!
Old Oct 11, 2010 | 06:58 PM
rebel350's Avatar
rebel350
help!
i have a 97 7.3 psd and it wont start. I replaced the cps, icp changed the oil, and pulled the driver side valve cover and checked the harness (havent had the chance to check the pass side) its gettin fuel to the top of the motor and i can smell raw fuel coming out of the tail pipe y wont it start?
Old Oct 11, 2010 | 09:10 PM
hawgystyle's Avatar
hawgystyle
Check the Glow Plugs, my truck wouldn't start when my Glow Plugs went bad. I believe yours are under the valve covers since its the powerstroke, sounds silly but that can cause it
Old Oct 11, 2010 | 10:44 PM
polarismuddman's Avatar
polarismuddman
x2 on the glowplugs..... did you reset the KAM after you replaced those things?
Old Oct 11, 2010 | 11:25 PM
rebel350's Avatar
rebel350
not sure what the kam is
Old Oct 11, 2010 | 11:29 PM
rebel350's Avatar
rebel350
guess not. Not sure what the kam is
Old Oct 11, 2010 | 11:34 PM
rebel350's Avatar
rebel350
but would the glow plugs make it just shut off and then not start again?
Old Oct 12, 2010 | 05:39 AM
hawgystyle's Avatar
hawgystyle
I had to replace the glowplug box in the back cuz it was shot too. (Sorry early in the morning and i cant remember parts easily)
Old Oct 12, 2010 | 05:40 AM
hawgystyle's Avatar
hawgystyle
So you were driving and it shut off or did you drive it turn it off and then it never started again. Just need a little more info from ya
Old Oct 12, 2010 | 02:20 PM
rebel350's Avatar
rebel350
well i replaced the
tie rods on labor day let it warm up
to take it for a test drive and it
stalled backin out of the driveway
and hasnt
started since
Old Oct 13, 2010 | 12:32 AM
polarismuddman
KAM is the keep alive memory...you need to reset it every time you change a sensor (I do anyways) just pull the positive cable off the battery for around 15 minutes then hook it back up and give it a shot.
vcobler
Oct 19, 2011 03:26 AM
rebel350
22
Oct 12, 2010 07:30 PM
russkinnard
15
Apr 23, 2010 07:35 PM
rigoberto
Apr 10, 2009 09:51 AM
StuckTruck914
Offroad & 4x4
Sep 25, 2007 06:50 PM
