AC blows through defrost
Old Oct 10, 2010 | 08:10 PM
rebelmdb's Avatar
rebelmdb
I replaced my auto hubs with a set of Warn awhile back ago. I did not cap off the vacuum lines but have gone and bought some caps today. I will cap at the wheel and then where should I cap the line. I would like to cap at the source but not sure where or if that is the way to do it. Thanks
Old Oct 10, 2010 | 08:33 PM
zx250's Avatar
zx250
Of the next Riffraff East
The vacuum pump and solenoid is under the hood on the pass. side fire wall. I capped mine of at the soleniod. It's the only hose headed down.
Old Oct 10, 2010 | 10:50 PM
mclarengts's Avatar
mclarengts
My AC blows through defrost when I go in 4x4.. what's up with that?
Old Oct 10, 2010 | 11:05 PM
zx250's Avatar
zx250
You have a vacuum leak somewhere between the solenoid under the hood and the auto hubs.
Old Oct 10, 2010 | 11:07 PM
mclarengts's Avatar
mclarengts
How do I track it down?? Is there a write up on it? Is it expensive?
Old Oct 10, 2010 | 11:30 PM
zx250's Avatar
zx250
Most likely a cracked line where it attaches to the hub. Look behind both front weeks and find the rubber hose, look where it slides over the barbed nipple. If it's cracked or broken, repair or replace. You can start there and trace lines back to the vacuum pump.
Old Oct 10, 2010 | 11:31 PM
zx250's Avatar
zx250
Should say behind wheels
Old Oct 11, 2010 | 01:25 AM
mclarengts's Avatar
mclarengts
Cool thanks
Old Nov 13, 2010 | 12:26 PM
rebelmdb's Avatar
rebelmdb
My internet has been down. I replaced my pump and capped at the wheels also removing the line all way back and capping it. Still blows out the defrost. Any other places I should check.
Old Nov 13, 2010 | 12:43 PM
PaysonPSD's Avatar
PaysonPSD
Check the vac line that goes to the HVAC system. You didn't cap that off did you?
Old Nov 13, 2010 | 02:55 PM
rebelmdb's Avatar
rebelmdb
No I didn't cap that one off. Where does that one lead to? Also when I put in 4x4 it blows normal for a minute.
Old Nov 13, 2010 | 09:24 PM
PaysonPSD's Avatar
PaysonPSD
It goes to the HVAC controls behind the glovebox. Open the glovebox and gently bend in the ears on each side and the glovebox door will drop down to give access to that area.
This is a pic from my colder AC mod so ignore the translucent yellow vac line going to the white tee. That is part of the mod. All the other vac lines are stock. I don't know which one actually goes to the vac pump reservoir or if it is actually pictured but it routes to here somewhere.
ezambrano3
Oct 7, 2015 01:40 PM
Vince79vette
Dec 3, 2014 09:29 PM
Cougar54
Jul 20, 2014 04:30 PM
JoeyIQuit
Jun 24, 2012 12:55 PM
Nobby
Dec 18, 2011 09:16 PM
