D6AE-B1A Anyone know?
Old Oct 10, 2010 | 06:45 PM
johnson2007's Avatar
johnson2007
I broke the nipple off of a little piece that was connected in-line of a hose that goes from the air cleaner to the preheat duct that runs down to the exhaust manifold. One side (the blue side) says VAC/MTR and has the number D6AE-B1A and the other white side says A/CLR and 8 HR. Does anybody know where I can find another one of these? I assume it is just some sort of check valve that only allows air to flow in one direction. Any help is appreciated. Thanks!
Old Oct 10, 2010 | 08:07 PM
steponit's Avatar
steponit
Do you see it here ?
http://c2c.activant.com/ctoc/index.j...RCVlA6BFQLV3kf
Old Oct 10, 2010 | 09:09 PM
johnson2007
The first link wouldn't take me anywhere but the second link isn't the part I am describing. I found a picture of it in a chilton's manual and it says it is a retard delay-valve. I have removed all of the smog equipment so maybe I don't even need this but I'm not sure if you have to have this valve to allow the warm air from the manifold to enter the air cleaner.
Old Oct 10, 2010 | 10:13 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Check the illustration from the Ford parts manual. Are you talking about basic p/n 9E897?
If thats the right part.
Vacuum Assy. (air cleaner duct vacuum control)
Fits 77-up F100-350 w/ 351M400
D6AZ-9E897-B
Blue/White
Green Sales has 2 (800)543-4959
Antique Auto Supply has 1 (817)275-2381
Miller Obsolete Parts has 1 (607)722-5371
Bob Allen Ford has 1 (913)361-3000
Click on the .pdf link to view the illustration.
File Type: pdf
Old Oct 10, 2010 | 11:00 PM
johnson2007
Yes, that is the part I was talking about. What is it for? Do I actually need it?
Old Oct 10, 2010 | 11:05 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Not sure if you actually NEED it. I believe it is either a restrictor to control the flow rate or a check valve, not really sure.
I don't see a problem hooking the vacuum motor (9D612) up direct.
Old Oct 10, 2010 | 11:16 PM
johnson2007
Thanks for the help!
CharlyG
Sep 20, 2016 11:46 AM
justin5227
Engine Swaps
Jan 27, 2016 11:09 PM
mrcman58
Ford Truck Parts for Sale
Sep 26, 2015 10:30 PM
deced
15
Jan 9, 2007 01:45 PM
Annihilator
Nov 20, 2004 11:52 AM
