86 f150 is sick
Old Feb 23, 2003 | 03:29 PM
ols0051's Avatar
ols0051
86 f150 is sick
86 f 150 efi,was running fine and just quit. has no spark. It has new wires,plugs cap rotor. It turns over fine . Just tried a new coil,no luck. Could it be the tfi modul? Any ideas would be very helpful. Thanks.
Old Feb 23, 2003 | 03:44 PM
desperado_18_2000's Avatar
desperado_18_2000
86 f150 is sick
If the TFI has never been changed on the distributor, it certainly couldn't hurt, and it would eliminate the problem on down the road for a while.
I'd replace it just for this fact, but have it tested first, and then get it replaced.
Autozone should be able to test it for you.
Old Feb 26, 2003 | 03:29 PM
The Weezle's Avatar
The Weezle
86 f150 is sick
Before you go out and buy an ignition module spend he $13.00 on a Hayes manual they give the complete test proceedure for checking it . My 86 302 had a bad ground and I would have bought the new module and it still would not have worked. The only tool needed to troubleshoot is a VOM( Volt Ohm meter) it's actually pretty simple to do.
86ford86
May 13, 2013 11:45 PM
baverwolf
Sep 17, 2011 07:09 PM
fepowerguy8
Jan 18, 2011 08:36 AM
duckslayer51
Jan 31, 2009 11:16 PM
badeep
Jul 31, 2003 12:59 AM
