1981 302 running hot!!!
Old Feb 22, 2003 | 08:23 AM
bastalker's Avatar
bastalker
Hi I am a new member. Yesterday I replaced thermostat, and water pump.I also flushed out the system.The temp gauge was running just below the line at the far right by H, and the hoses had alot of pressure on them. After doing all this work, temp gauge runs AT the line to far right, and still have the pressure buildup. What else should i try? Radiator clogged? Any suggestions would be greatly appreciated. I use it for snow plowing. TY
Old Feb 23, 2003 | 01:11 AM
pbrstreetg's Avatar
pbrstreetg
It sounds like what you said- flow through the radiator (clogged).
Old Feb 23, 2003 | 02:19 PM
Franklin2's Avatar
Franklin2
Do you have any other indications that it is overheating. It may be overheating but:
The system runs about 15 pounds of pressure normally(depending on the rating of the cap)
The factory guage may not be reading correctly.
If it was running hot it would more than likely:
Ping on acceleration,
Boil over and puke out fluid.
You are there, and can give the best judgement, but I wouldn't rely totally on the factory temp guage. Go buy a cheap mechanical one.
Old Feb 26, 2003 | 03:38 PM
The Weezle's Avatar
The Weezle
I seem to be on a test kick here today but its simple to find out if the gage or the temp sensor is bad. to test the gauge ground the wire that attaches to the temp sending unit turn on the key gauge should go all the way over if so it's not the gauge. temp sensor can be check by starting with the engine cold and attaching an OHM meter to the temp sensor end and ground start engine and bring to temp resistance should increase if not replace sensor. Sounds to me like you have a plugged radiator. Just replaced mine on my F150 with a 302 had the same symptoms......Good luck. Advanced Auto sells new radiators for $158.00 solved my problem
1972RedNeck
Mar 22, 2015 12:07 PM
86F150302
16
Dec 24, 2008 02:08 PM
tomtoc
15
Feb 11, 2008 09:08 AM
Spaceman Spiff
20
Aug 16, 2006 05:37 PM
cpd806
Modular V10 (6.8l)
Jan 4, 2006 08:25 PM
