86 f-150; no power
86 f-150; no power
So I just replaced the solenoid is my truck due to starting problems only to find I now have zero power getting to my headlights, cab etc. I checked my battery and solenoid which both are receiving 12v of power. My fuses are fine and zero arc when installing the new solenoid. It started just fine (minus the turn over problem/ read other thread/) before the new install, now nothing...
sounds like you either left a wire off the solenoid when you replaced it, or put it on the wrong side as he said.
the proper wiring has only the fat starter wire on one side, and everything else with the battery wire on the other side.
i haven't read your other thread, but with all the wires on the wrong side you wouldn't be able to do much of anything
mnmsutton
11-14-2014 12:49 PM
jdwest1961
02-08-2014 11:25 AM
superman400
04-12-2011 08:00 AM
Ohydro91
04-01-2011 06:34 PM
