Common air cond failure?
2012 6.2 XLT 50,000 miles with manual single zone controls.
I haven't had time to work on it yet, but it seems that my AC compressor is not engaging. The dash controls light up normal, fan comes on, etc.
I am just looking to see if there are any common failure points.
I know it COULD be low on charge, clutch could be bad, etc.
I am just checking if there is a common failure with these trucks AC system.
Thanks
Thanks
WRONG. Think about what A/C stands for. Air CONDITIONING, which doesn't necessarily mean cooling. When your mode selector is placed in the FLOOR/DEFROST position, it means the desired outcome is to defrost/defog the windshield (most noticeable during rainy weather). The purpose of the A/C compressor cycling in this setting is to remove moisture from the air, so as to achieve the desired purpose.
Which, as a Ford dealer licensed tech, I've seen my share coming through our shop. An easy way to confirm a failed evaporator would be to add A/C dye to the refrigerant, and watch for dye traces exiting the drain tube on the firewall while the A/C is operating.
I understand that the AC system activates to reduce humidity to help keep the windows clear. Why would you tell him he's wrong? He isn't.
natedog37
15
09-26-2017 11:00 PM
cbird
03-20-2004 01:17 PM
