Radiator Support Mounts
Does anyone have any info on the specs. for the radiator support mounting hardware and rubber bushings?
I'm specifically looking for the rubber bushing thickness and bolt length.
I'd like to make my own.
How do these F'ers sleep at night charging what they do for two pieces of rubber, two washers, a bolt and nut? It's not like they're recouping R&D costs.
67-71 measurements sound good but there has to be a reason the 72 is different. And as per Murphy, I have a 72.
What is FESM?
Front End Sheet Metal. That's how they are listed. I can't see how 72 wouldn't use the same as 67/71. Core supports no different. Frame not either. That 1972 entry has to be wrong. I was just stating what was listed. Note Ford only listed the one for 72. Not an upper and lower.
No there isn't. Other than what I posted above. Note the basic numbers 00154 and 00155 both in Bill's pic. Those are what I posted the sizes for above.
I know what you mean Bill. The trouble is 72/ only shows the one part number. That Dent number you and I have both referenced now and in the past. Not an upper and lower. At least the upper would have to be the same as 67/71. The 5005 frame and 16138 core support part numbers didn't change in 1972 to reflect different mounts as you know. So an upper mount's dimension can't jump that much different. I can understand if that taller D3TZ was then used as the lower. But 1972/ catalog listing makes no sense. Unless "in 1972" they designed the D3TZ mount for the 1973 new body style and it then got slipped in to the 65/72 catalog under 1972 Bumps by accident. I am shocked no Parts Manager brought this to Ford's attention back in the day to get corrected.
I don't recall ever looking up any of these parts until I showed up here (11/4/2006) on FTE
I called that 800 number at least once a week to report errors in parts catalog. Some were corrected in later editions.
Sorry for the late reply. I see your referencing a manual.
This sucks. I would imagine the height and placement of these bushings might be kind of important for proper body parts alignment. Not something that can be " adjusted as you go ".
How many people were replacing cab mounts "back in the day?"
I think if you go by the 67/71 dimensions I posted in post #2 you'll be fine. If you measure your existing worn out mounts their dimensions are prolly close to the new 67/71 ones. Because they were originally one in the same.
IF.... the number for the 72 and 73-79 is a total thickness of the two bushings then each bushing should be 1+ 3/16th" approx. Round again and say 1 and 1/4" . That's only a 1/8" difference ( approx. ) between the totals . If we take a 1/4" off of one and add it to the other, then we have one that is 1 and 1/2" approx. ( upper ) and one that is 6/8" approx. ( bottom ). Pretty close to the 67-71 thicknesses.
Until I get info saying otherwise, I'm going to use what you guys confirmed for 67-71.
If I come up with any harder knowledge I'll share.
Thanks guys, Todd.
The most important thickness is the top one since this dictates the height of the front of the quarters, grill, hood and inner fenders. Right?
Thanks guys, Todd.
Thanks guys, Todd.
Thanks guys, Todd.
NMFirstF2504X4
04-01-2018 10:07 PM
ecidemon
09-06-2011 04:24 PM
FitchBanjos
04-04-2008 10:36 AM
