My computer went crazy today
Truck was running fine. I dropped off a return at the Home Depot PRO desk (truck off). Started the truck and moved to PRO parking and parked nose-to-nose with some kind of older RAM with a chrome bumper (did not touch front ends).
Did some shopping, got back in the truck, started it and:
Computer restarts.
Message flashes: adaptive cruise not available
Message box: check manual (ok)
Message flashes: pre-collission not available
Computer restarts.
Message flashes: hill start assist not available
Check engine light on.
I wondered if it had to do with parking so close to the RAM? So I drove it to an empty space, shut it down, waited a moment, started it back up -- same thing.
So I drove it to the ford dealer (5 minutes away). Shut down / restarted for service writer -- no messages -- just check engine light.
He tells me it's an all day thing, and they are booked up. Make an appointment.
I figured forget that, I'll just clear it myself and see what happens.
Using Torque Pro, I pull the codes and all I get is this:
P2610 - Powertrain
M/PCM Internal Engine Off Timer Performance Fault
So I clear the codes, the check engine light turns off. I shut it down, restart it, and it seems fine. I drove it about 5 miles and it's parked now.
The only other 'variable' I know of is I was trying to set up the DPF monitors in Torque Pro and couldn't get them working -- right before I went in to Home Depot. But I'm 99.999% sure I didn't write anything to the truck.
So I don't know if it's parking close to a metal bumper, messing around with Torque Pro, or something else. Scratching my head, but happy with no error codes at the moment...
Computer restarts.
Computer restarts.
P2610 - Powertrain
So I've made two trips since. Everything is fine. My best guess is:
1. Starting the truck with the sensor that's inches from a large metal surface scrambles the computer's eggs.
2. I kept turning it on and off trying to see if it would clear. I suspect that caused the P2610 fault (which if I understand correctly means it can't determine how long it's been running) -- due to more brain scrambling from the on/off/on/off/on stuff.
I'll report back if there are other issues. Meanwhile I'd love to hear from anyone who gets any similar symptoms and especially if they were up against a big sheet of metal when it happened.
on
This isn't exactly the same thing but I noticed on my 2011 that if Torque Pro was running the truck would sometimes randomly throw an error code. I attributed it to a bandwidth issue of the truck's computer or OBDII port. I read once that by simply listening to too many PIDs can actually interrupt internal communications. This is only a theory on my part supported by a post somewhere else.
It's more likely that on startup the related module glitched and didn't communicate properly therefore throwing a code. I think this is something that we are only seeing the beginning of. Truck glitches and the fix is to reboot.
I removed the dongle, restarted the truck, zero issues.
Thanks for this!
