Changing the transmission filter
New to me 2006 F350 6.0 dually. Going to change oil and filter as well as the transmission fluid. I did a search and got all kinds of answers but they were old threads so I thought I'd ask.....again.
Should I replace the transmission filter on the Auto I have or just have Jiffy Lube do their thing?
The filter up front, looks like a roll of TP. Use an impact wrench, do it yourself. The filter inside the Trans pan is for rocks and trees.
You could upgrade that to the 08' pan and filter, it does 100% of the oil instead of 10% in by pass and then throw the bypass TP filter in the trash. Best $93 you'll spend, make sure you use Mercon SP or LV.
Tranny fluid is easy on a Torqshift as there is a drain plug. If you can change your own oil you can do the tranny fluid. It's 8-9 qts so make sure you have a big enough pan.
As watson said the stock filter is good for the life of the tranny so no need to drop the pan. Just do the "toilet paper" filter.
Many go for the 6.4 filter/pan. About $100 in parts and you get much better tranny filtration.
Knowing the tp filter is a smaller micron sized filter then the 07 and "assuming" it's smaller then the newer 08, why wouldn't you just install it, knowing that that additional filtering can't be bad. Seems like a good option not used?
Guess I'll have to see if there's info out there to answer that.
When the time comes to change mine I'm going to go with this. 5R110 Transmission Filter (2003 & UP) (For Use w/ 6.4L Trans Pan)
I talked to Ed and it's a better full flow filter than the '08 and up Ford stock filter. Have to use the 6.4 pan though.
minimum wage want to be grease monkeys to do things correctly.
Stick with OEM filters. Someone can post the crossover list of
who makes what filter
The problem with the non OEM type filters is that they use adaptors
that can fail and let plastic go where it was not meant to be or have
a taller cap that the filter fell out of and someone replaced it with the
correct filter and not the cap. That lets dirty oil past the filter.
And I could go on.
Sean <BR>
6.0L Tech Folder
Maybe he'll jump in here and tell us about it...
I swapped to the 08 pan and filter. I also run the stock bypass filter that's stock up front. There's no reason not to really. I probably just won't change it as often now. They're cheap enough now and the more filtering the better.
