- which engine
- flex fan vs. electic
- Looking for a machinist in Southern California
- F-150 Harley engine block
- went drag racing tonight got.....
- Does the engine require more spark after rod and main bearing change?
- Truck will not start after new rod and bearing change
- first time setting timing on 351w
- 460 buildup
- Cheap 5.0 Buildup, got some ?'s
- Do I need egr
- Blue Racer Part # Help.
- Need Oil Pump Advice
- Problems with Fel-Pro MS90618 intake manifold gasket
- need help choosing degrees of advance
- 400 or a 460!
- 390 combo help?
- I need help with timing
- trouble after changing transmission fluid and filter
- quick question about the valvetrain
- A thread I read
- Need help identifying engine
- Bog down & Backfire
- Urgently Need Suggestions on 302 Rebuild...
- Cams
- Explorer 5.0 into 89 150
- just a quick head question
- backpressure theory discussion
- Best engine for my build
- knocking 302?
