Help?? F-350 Crew Cab,7.3L Powerstroke Unexplainable Shut Off
Old 10-01-2010, 03:35 PM
Brother Les's Avatar
Brother Les
Brother Les is offline
Reps to Clay for offering an over the phone consult and getting Cowboy Mark all fixed up
  #32
Old 10-04-2010, 08:53 AM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
Fixed up AND fired up!
Reps
  #33
Old 01-06-2016, 08:41 AM
Kstates's Avatar
Kstates
Kstates is offline
Mine is an 01 and if your drving and you let off, it acts like you turned the key, but you turn it over and fires right up ike nothing?? I cant figure it out but it seems to only do it until it gets fully warm
  #34
Old 01-06-2016, 08:59 AM
BillyBob69's Avatar
BillyBob69
I would start with the CPS. Known issue. New one costs about $25 - $30 Takes about 5 min to change out.
  #35
Old 01-06-2016, 09:24 AM
Brother Les
Mine did that a couple of times and it happened when I drove through some water. It seemed that moisture was getting into the CPS or the connection and would instantly shut the truck off. It would always 'start' right back up and I was able to go on my way. My suggestion before just saying that it is a bad CPS, (buy one to have a spare), take out the CPS and clean it and the connections and put it back in and make sure the connection is very good and use sealant around the CPS and connection really well.
The 'seems to only do it until it gets fully warm' seems to be a good clue.
Welcome to the forum.
georgia7.3
18
12-26-2018 07:41 AM
RedDevil460
08-12-2016 06:07 AM
Medic4.life
07-03-2016 11:02 PM
Penton97F150
1997 - 2003 F150
06-26-2016 10:49 PM
Eric3501
16
06-06-2016 11:15 AM
Quick Reply: Help?? F-350 Crew Cab,7.3L Powerstroke Unexplainable Shut Off
