Troubleshooting 2002 7.3
He told me that he dropped the tank, and the pickup was missing. He put that back on. I asked some indirect questions about the screens in the tank, but they hadn't messed with them. He said all of the cylinders compression checked out between 380-390psi. He said he was tired of the truck, and it wasn't worth wasting his time and money on it.
Now here is where I come in. The truck smoked a lot (white with the smell of diesel). It had no power when I went to test drive it, and I wasn't going to buy it. The owner got in, and we drove maybe a quarter-half a mile and it was like flipping a switch. I figured it had to be something small so I bought it. The first thing I did was drop the tank. I cleaned it, did the hutch and harpoon mod and added the Racor ps120-02 fuel filter assy. pre screen. The screens were almost completely stopped up. I am surprised it could get diesel through them at all. I cleaned on some skinned wires and other odds and ends under the hood. Still no change.
I checked the resistance of the pins for the glow plugs and injectors on the large harness on the drivers side. The glow plugs all checked out good. MY results for the injectors were as follows:
The passenger side bank all checked out at 3.1-3.2
2 - 3.6
4 - 4.6
6 - 3.6
8 - 4.2
I used a generic scanner and the codes came back for the intake air temperature sensor (1) and exhaust back pressure sensor. The intake air sensor had been chewed off by a rat so I got one out of the pick a parts. They had changed the ebps, but they didn't clean the tube. I took the tube off, cleaned it and put it back. The codes kept saying it was no good so I ordered a new motorcraft one. It still smoked bad, but I think it was a little better.
I really wanted to avoid buying auto enginuity right off the bat, but after reading about it here and other sights, I felt like it was way cheaper than throwing parts at it like the last guy. I received it yesterday about midday. When I hooked it up, I did a buzz test first off. They all sounded really strong. The 6 was maybe a tad off, but it still sounded strong. I cleared out the codes, and the only thing that came back was the p0475. I got to looking for the valve last night, and I discovered the wires being cut or chewed off right at the plug. I couldn't find the wires that go to it last night or today.
I warmed up the engine, and did a cylinder contribution test and the perdel test. Codes for cylinders 2, 4, and 8 failed the contribution. When I looked at the perdel, 2 and 4 were between 2-4% but 8 was at 9%. I figured 8 had not been changed out according to the original owner, so I decided to go ahead get one. I called around, and found one at the same place where the original owner said he had gotten his. They had it in stock, and I made it there before they closed.
I took it all apart after lunch, and I put the new injector in. I got it put back together and started, and I immediately felt a difference in the truck. I drove it for a test run in the neighborhood, that turned into about a 10-15 drive. I drove it hard trying to get all the air out. I stopped and filled it up with diesel, and checked the perdel numbers while filling up. They were all sub 1.0 with the exception of number 8. It was between 3-4%, but I understand that that is normal. I got it back home, and I turned it off to check everything out.
When I turned it back on, it lost power like it did before. The perdel numbers were off the wall for cylinders 2, 4, and 8. Two and four were between 4-6% and 8 was like 11%. It dumbfounded me. I did a KOEO test, and a P1294 code came up. It was pretty warm, so I let it cool so while I came in here to do a web search. Now, I know that is a drivers side bank code. And what I read, it is most likely the under valve cover harness not connected well. I ran an errand, and when I came back I did a buzz test. It sounded just like the one I did yesterday. I cranked it up again, and took a screen shot of my perdel test. 2-5.1%, 4-4.5%,6-0.7% and 8-2.4%. The passenger side was all 0.0.
It was still to warm to dig into it, but I would like some feed back. If it buzz tests fine, but it perdels poorly, could it still be that harness? I cleared out the p1294 code, and it doesn't come back now. I seriously doubt that he put motorcraft valve cover gaskets in it ( the part number on his printout of all that he did to the truck comes back as a felpro), should I go ahead and get a motorcraft valve cover gasket and under cover harness?
I know this is a long post, especially for a first post, but I would really appreciate your feed back if you have time. I really do appreciate all of the help that I have received already from previous threads. Thank y'all in advance.
Depending on which kind are on there, the plastic locking clip on the Dormans can be tricky to get not-upside-down
Also inspect the connector for damaged pins or sockets.
If you have wiring damage, check to be sure nothing has been laying on the engine or other metal area and rubbing through or shorting.
Have you replaced the rubber lines on the intake side of the fuel pump and at the tank? The quick disconnect fittings there fatigue (orings) and it sucks air.
Air = Anchor to a diesel
Do you have a way to test the fuel pressure? Make sure you use one for diesel that goes to 100psi, not a gasser up to 15 or 30psi
Hope this helps a bit
It supposed to be relatively new. You may be right, that I just need to go ahead and pay to replace it. I just hate that it is Saturday. I don't think I will be able to find a ford or international dealer open today if I need the gasket and/or harness. I really don't want an aftermarket one.
As far as the fuel line, I did replace the suction side of the fuel line. I left the factory connection on the return line, and I have not seen any leeks. I have a fuel pressure gauge. I checked the pressure on the upper port of the filter housing, and it showed between 53-60 psi. It was around 60 sitting in park. It would be about 53-55 when I tried to mash on it before I fixed the injector. At that point, it poured out white smoke that smelled like diesel. Sometimes were worse than others, but when it was bad, it just seemed to be a fog around when it was running. I am going to check out the UVC gasket and wiring, and if that doesn't fix it, I will check the fuel line connections just to make sure. I have not checked the fuel pressure since I changed the injector, but I don't think that is the problem. I could be wrong, but the more I look and read about it, I think it has to be something with the wiring.
Now, It doesn't smoke like it did. When I left on my test run yesterday, It smoked for the first few miles really bad, but I am guessing that is from the residual diesel/oil left in the exhaust and cylinder from the injector change. I got all that I could out of the cylinder, but I understand that it is normal for them to smoke pretty bad after injector work. I stomped on it up to about 60 mph, and then let off to slow down. I repeated this about 2-3 more times, and the smoke pretty much went away. I don't think it smoked again until I got it back home after the test run and it started acting up again. Even then, it is nothing like it was. As soon as I got home, the exhaust smelled like what a diesel engine should smell like. No real smell of diesel. I grew up on a farm, and I don't know how else to describe it. Before, it smoked no matter what. Now, it pushes out a little puff if you push the accelerator a little. No lingering cloud of diesel.
Thank again for the input. I will let y'all know what I find.
Almost sounds like you didn't get all the air out or the oil. Once running smooth turn off engine and see if you hear it gurgle. That means air is still present. Can take 100 miles to get air out.
I broke my ebp sensor and the local ford wanted a lot more for it. I told them I could get it for less in Motorcraft online and they came within $10
I guess I need to check my fuel line connections as recommended earlier. I guess it is possible that it is sucking air. But that shouldn't have anything to do with that code right? What else could this be? Is there anyway to check the resistance on the male side of the 42 pin connector? If so, what should the ohms be? My dad drives a company truck that is the same year, engine and transmission, but he lives 4 hours away. I wish I could borrow his IDM. I don't know anyone else that has one that I could borrow. Is the IDM even a possibility, or would that never correct itself? The Dorman kit came with a plug that you can splice into the existing wiring harness on the outside of the valve cover. I didn't put that on, but that should not be the problem since it ohmed out right? All advice and suggestions are appreciated. Thanks for the help so far.
You can do a load test on the wires using a 60 watt 12v bulb, connect bulb to injector plug and apply 12v to the other end but make sure you put a 10 amp fuse inline in case of a short. If a wire burns up, light will go out and you found your issue.
