Driveshaft vibration AGAIN!!
Hey all I was on my way home from the Outer Banks of North Carolina this evening and my driveshaft vibration came back.
The history is that a while back I had a bad vibration and found my driveshaft had to be rebuilt. New CV and three new u joints. My vibration went away and all was well. Today about 4000 miles after the rebuild with upgraded u joints the vibration came right back.
The problem was fixed the first time but what could be wrong to do this again? Bent driveshaft? The truck has never pulled a trailer or been bottomed out, its a highway cruiser.
Thanks for any imput guys.
Brian Felts
Brian Felts
Both of My Excursions have had some sort of driveline vibe. My newest (01 7.3 4X4) didnt have it when i bought it about 5000 miles ago. Only after the local dealership change a leaking pinion seal did it have a slight vibration. my 03 V10 4X4 had it bad and I never could fix it. Three driveshafts (including a brand new CV shaft), rebuilt rear, transfer case output bearing- you name it, i tried it. Neither of my X's had a factory CV shaft. The V10 had a regular shaft and the diesel has the same shaft but with the rubber dampener on it. good luck. i have become accustomed to it.
I would work the parts issue. Look at the receipt and find out what parts were installed and what choices the installer had. I would bet it MADE IN CHINA on the box. On some of my problems I get 3 or more bad parts where it changes the symptoms. Is the vibration exactly like the first time?
Temecula
d
Temecula
d
