51 F1 3 on the tree can't shift into 2nd & 3rd
Hi all, the truck is looking great and will post pictures soon. Big problem!!!
We are giving my Father in-law the truck on the 25th and we just found that we can not shift into 2nd and 3rd.
We can shift into reverse and into first just fine but not 2nd or 3rd.
I see when you shift from reverse and into first the linkage moves just fine and when you move the shifter for 2nd and 3rd, it looks like the levors move down the shaft but I am not shure if they have to separate or stay together. Any one have any ideas for me on how the shifter works?
Any information will be a huge help.
Thanks all,
Mike
Thanks all,
Mike
That's good stuff, Ross! I just printed that off and added it to my 'book of knowledge'.
Mike,
After you read Ross' tutorial and learn how the linkage is supposed to work, if you can't tell what the problem is still, try taking the 2-3 linkage off from the transmission and see if the shifter works then. That way you'll know if it's a shifter problem or a transmission problem. Make sure you're actually getting the trans in neutral when you put the shifter in neutral and it's not hanging up somewhere in the R-1 linkage. If you're not getting neutral in the R-1 linkage, the 2-3 shift won't work. And be glad it won't. ;-) The last thing you want to do is jam the trans into two gears at once.
Mike,
I was thinking the wave washers.
I am being told now that both levers are moving at the same time and only one should be moving. Almost like the R/1 lever is conected to the 2/3 lever and it will only find R/1. Do the wave washers separate the the R/1 and 2/3 levers when shifting?
Thanks,
Thanks,
h8jfgrdn
05-22-2016 09:57 PM
cutmoney
08-03-2015 07:16 PM
