Gas Cylinders anybody?
Does anybody know what all those stamps on compressed gas cylinders mean? A guy at work found one in his mothers basement and was going to throw it in the scrap bin but I brought it home. He thinks his brother might have used it for a keg (CO2 ??). It has a regulator attached to it that goes up to 60 psi. Knowing how expensive these are I wonder if I could swap it for a full bottle down at Tractor Supply for some MIG gas +$25 to have it tested like when I got my oxygen bottle. ANYBODY??
Ok here.
https://www.ford-trucks.com/forums/p...ictureid=47436
https://www.ford-trucks.com/forums/p...ictureid=47435
https://www.ford-trucks.com/forums/p...ictureid=47434
The reg have a valve attached to it but when I tryed to turn it it broke off.
The cylinder valve shows it's a CO2 cylinder and regulator (and the portion of the nipple inside the regulator nut should look like this picture):
Western #806 Carbon Dioxide Adapter CGA 320 To CGA 580 Argon/Nitrogen
These fittings take a gasket to seal, so if you use it get a few, they are cheap. Your local welding supply will have them.
Hobart make a kit
Weld Talk Message Board and Online Forum - Hobart Welders
to use paintball CO2 tanks for portable use with their small MIGs, and you could do something similar (your cylinder holds more gas). The Western #806 adapter above will adapt it to a standard welding regulator.
I'd rather have a personally assembled setup (and I do) than the Hobart kit, since after getting the parts together I can use ANY size cylinder and a standard regulator as oppose to paintball cylinders.
If you get into it you can transfill as you would transfill a paintball cylinder, but that's a subject for another post.
The bad:
Tractor Supply will likely have NFI (No Faint Idea) what to do with your cylinder, so a (friendly) local welding supply would be where to swap it out, and they likely won't stock one since it's around lab bottle/lecture bottle size so you'd have to wait.
The regulator is junk and not a welding regulator. If you unscrew/saw off the nipple you can use the nut for a thread protector for the cylinder valve.
It doesn't hold enough gas for more than a short time welding. Purely for portability, but portability can make the difference between getting a job done and not being able to tackle it. It beats the paintball cylinders though.
I've been collecting a variety of cylinders off Craigslist and getting them swapped out. Helium cylinders (popular with stores that use them for filling balloons) can often be swapped for other cylinders that take a CGA 580 valve such as argon and mixed MIG gases.
That ain't old:
B-B-Baby, you ain't seen n-n-nothin' yet, You ain't been around - Unlike this O2 cyl. - WeldingWeb™ - Welding forum for pros and enthusiasts
I'd keep it and add it to the cylinder collection every welder should have.
Hobart make a kit
The bad:
I'm looking at some other bottles I have and it looks like this bottle in question was last tested 06/74
High-pressure cylinders are required to be hydrotested every five years unless the last certification stamp has a star stamped after the date, in which case the test is good for ten years.
Joe
We've got 1907 and 1909-dated oxygen cylinders still in COC exchange service.
Typical Fords, what few there were, when those cylinders were made (and gas welding was the standard for most vehicle repair):
A Picture review of the Model T Ford
1919 Welding Manual (many excellent and still applicable welding manuals can be found here):
Oxy-acetylene Welding Manual : Lorn Campbell : Free Download & Streaming : Internet Archive
Cylinders are easily the oldest equipment in mass use. (Pics of some of those you mention would be cool for "oldest cylinder" threads in welding forums!)
Nice T site. Good number of acetylene generators and B bottles in the photos.
As for the subject CO2 bottle, it's probably not worth dealing with IMO. Too small for welding, and not a common size anymore (at least not around here). We've only got one, and it's out of service and likely to stay that way. The most common small CO2 sizes in circulation for welding and beverage service exchange are 15 and 20 lb.
Joe
choate
10-05-2014 11:59 AM
lastchance
15
05-13-2002 08:55 AM
