Anybody know the trick to getting that bottom squeeze holder through the hole??
I use a deep 14mm 12pt socket around the lower retainer to depress the tabs while applying some pressure to the back of the headlight, it pops right out.
It is a joke. I replaced a bulb while om the road last month. Had to unbolt my coolant filter and remove the driver side battery and battery box. Pain in the ***!
