Removing pitman arm
Removing pitman arm
What is the best way to remove a pitman arm on a 52 ford truck. I took the drag link off yeaterday and on the pitman arm the ball has a flat spot on it so I ordered another one yeaterday. Now I have to get the old one off. After I get it off how do I line it up as close to where the old one was so my alinement will still be the same?
DIADQ
You'll want to get a pitman arm puller.
How it works is fairly obvious but there are some finer points that aren't. Apply stout pressure with the press screw, but don't overtighten it or you'll damage/bend the tool. Once you have it under pressure, whack the end of the screw smartly with a hammer a couple times followed by whacking the side of the pitman arm in the area of the splines between the fingers of the puller. Tighten the press screw a half turn or so and then whack it in both places again. If you can't get it to move, soak the splines with penetrating oil and let it sit overnight under pressure from the puller and repeat the bash and tighten routine. Some are more stubborn than others, but they will always eventually come off.
It's been a day or two since I had a pitman arm off, but I want to remember that the pitman shaft and arm both have a master spline, so it's only possible to put it back on one way.
DIADQ
BOR shows the same puller I have and it works great, but on some trucks that specific puller tabs will not fit behind the pitman arm (for some reason the space between the frame and the arm is narrower) so you may need to use a ball joint tool like this one.http://www.northerntool.com/images/p...9094003_lg.jpg
qmcdugan
07-18-2016 08:04 AM
MIKEDENGINEER
05-09-2014 07:50 PM
Tectron1
08-09-2004 08:48 PM
