rusty drip edge
rusty drip edge
Hi Guys
Bought a 56 f100 recently and it has small rust holes right above the water channel above the windshield and above the doors. Since I know nothing about body work, I was wondering if someone could tell me if this something that can be fixed easily or if it is a tough fix
Thanks!
Thanks!
I'm not sure about the 56..but 53-55 the driprail is "sandwiched" between the roof panel and the rest..the repair depends on the amount of rust..if it goes THRU the rail and into the adjacent panel it could get tricky...three pieces to make and install.I suspect the 56 is the same.
I've heard some folks remove the rail completly for a different look..that could make things a little easier..
Hi Guys
Thanks!
Thanks!
there are also no patch panels or roof replacement sections for this problem.
Sam
If its just a tiny area its easily fixable but anything larger will be more tricky...
I've repaired small areas by removing any edges, treating the remaining metal then using fibreglass resin. You stick waterproof tape to the underside and then dribble the resin on top until it settles to the correct level. Then just leave it to set, and remove the tape the following day. As i said though, only suitable for tiny holes.
snotrod
05-25-2017 07:27 PM
Ray Sutorius
08-11-2015 11:05 AM
