rusty drip edge
Old 09-08-2010, 08:48 PM
skotyg's Avatar
skotyg
skotyg is offline
rusty drip edge
Hi Guys
Bought a 56 f100 recently and it has small rust holes right above the water channel above the windshield and above the doors. Since I know nothing about body work, I was wondering if someone could tell me if this something that can be fixed easily or if it is a tough fix
Thanks!
Old 09-08-2010, 09:14 PM
cmoritz's Avatar
cmoritz
cmoritz is offline
I'm not sure about the 56..but 53-55 the driprail is "sandwiched" between the roof panel and the rest..the repair depends on the amount of rust..if it goes THRU the rail and into the adjacent panel it could get tricky...three pieces to make and install.I suspect the 56 is the same.
I've heard some folks remove the rail completly for a different look..that could make things a little easier..
Old 09-08-2010, 10:21 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
Originally Posted by skotyg
Hi Guys
Thanks!
this is a typical failure place on the 56 above the brow.. hard to fix, mostly cause you have to get something to STOP the rust first.
there are also no patch panels or roof replacement sections for this problem.
Sam
Old 09-09-2010, 10:23 AM
WALFORD'S 56's Avatar
WALFORD'S 56
WALFORD'S 56 is offline
I have done a few roofs and the main problem is working up on the darn roof....LOL
When I was younger....I didn't notice that.....LOL
Old 09-09-2010, 10:59 AM
cmoritz's Avatar
cmoritz
cmoritz is offline
Bill, I found a couple of ways to overcome that hurdle..I sometimes use one of the picnic table benches,..and sometimes the table itself, make sure it's in good shape and able to carry your weight.Works great when buffing,sanding etc when you need your to cover the entire roof !
Old 09-09-2010, 11:51 AM
dawolverine's Avatar
dawolverine
dawolverine is offline
If its just a tiny area its easily fixable but anything larger will be more tricky...
I've repaired small areas by removing any edges, treating the remaining metal then using fibreglass resin. You stick waterproof tape to the underside and then dribble the resin on top until it settles to the correct level. Then just leave it to set, and remove the tape the following day. As i said though, only suitable for tiny holes.
snotrod
05-25-2017 07:27 PM
Ray Sutorius
08-11-2015 11:05 AM
Bite N Hold
03-09-2015 08:04 PM
labman1014
12-22-2010 08:19 AM
lariatf150
2004 - 2008 F150
06-04-2004 04:40 PM
Quick Reply: rusty drip edge
