PID Alert ?
PID Alert ?
So I just got the update for my Insight CTS and it added a few PIDs that are actually useful. But what should I set my alerts at? Here's a list of the PIDs I have after the first update:
Accel Pedal Position
Barometric Pressure
Batter Voltage
Corrected Vehicle Speed
Engine Coolant Temp
Engine Load ( still haven't figured out what this is yet)
Engine Oil Temp
Engine RPM
Engine Run Time
Injector Pulse Width (what is this and what kinda numbers should I be seeing?)
Intake Air Temp
Mass Air Flow
Trans Fluid Temp
Turbo Boost
This is what I have so far. They're supposed to be adding more though.
Barometric Pressure
Batter Voltage
Engine Coolant Temp
Engine Oil Temp
Engine RPM
Engine Run Time
Intake Air Temp
Mass Air Flow
Trans Fluid Temp
Turbo Boost
on
Barometric Pressure
Batter Voltage
Engine Coolant Temp
Engine Oil Temp
Engine RPM
Engine Run Time
Intake Air Temp
Mass Air Flow
Trans Fluid Temp
Turbo Boost
Barometric Pressure
Batter Voltage
Engine Coolant Temp
Engine Oil Temp
Engine RPM
Engine Run Time
Intake Air Temp
Mass Air Flow
Trans Fluid Temp
Turbo Boost
A few of those you really won't need to look at unless you are trying to diag a problem. I would actually concentrate on more of the traditional ones that would give you a "broad feeling" of what's going on.
Now I don't know if the CTS allows you to setup up what the DashDAQ calls "global sensors" and what that really means is that the PIDs that you setup under this heading are not viewed on the gauge screen, but when you hit the datalog button those "global sensors" are recorded as well as the sensors that are on the gauge screen. That's where I would put some of those sensors as that is where they would be the most beneficial.
The ones that I would concentrate on would be ECT, EOT, TFT, Boost, Battery Voltage off that lis that you gave. I'm not trying to mitigate some of the importence of the other ones, but unless you are trying to do some problem solving, just day to day driving they aren't going to be as much benefit to you as the ones that I specifically mentioned.
As to alerts, Bismics spreadsheet(if you have it) has the listing of temps that are either temps(or whatever the reading is in) to start worrying and/or temps(readings) to be avoided. You can decide where you want to set your alerts from that.
Barometric Pressure
Batter Voltage
Engine Coolant Temp
Engine Oil Temp
Engine RPM
Engine Run Time
Intake Air Temp
Mass Air Flow
Trans Fluid Temp
Turbo Boost
Barometric Pressure
Batter Voltage
Engine Coolant Temp
Engine Oil Temp
Engine RPM
Engine Run Time
Intake Air Temp
Mass Air Flow
Trans Fluid Temp
Turbo Boost
on
This is where knowing your truck is going to really be needed.
That's actually going to depend on where you live(both in terms of weather and in terms of topography), what(if any) tune you are running, how hard you are "pushing" the truck etc. Those factors will change dependant on rather or not the truck is loaded or unloaded, towing or not towing etc. Those aren't the only factors either. 190-200 is about average, however, it wouldn't be uncommon for an individual truck without issues to be running at 205 unloaded or even as high as 215 unloaded. 215 I might start to back off whatever I was doing, but that certainly isn't a temp to be worrying about needing a loaner truck for awhile. Also I have had normal unloaded decent drivers(more then 15 miles, but less then 100) were ECT never got above 180 during the winter.
[quote=AndeyHall;9301563]So I just got the update for my Insight CTS and it added a few PIDs that are actually useful. But what should I set my alerts at? Here's a list of the PIDs I have after the first update:
Barometric Pressure
Batter Voltage
Engine Coolant Temp
Engine Oil Temp
Engine RPM
Engine Run Time
Intake Air Temp
quote]
I would think you have EGT on that list also. I have that on mine. Yes they are supposed to have some updates. I havent got one yet though
Mass Air Flow
Trans Fluid Temp
Turbo Boost
Barometric Pressure
Batter Voltage
Engine Coolant Temp
Engine Oil Temp
Engine RPM
Engine Run Time
Intake Air Temp
quote]
Mass Air Flow
Trans Fluid Temp
Turbo Boost
on
Yes and no on the backup. Problem is, you are stating it to matter of factly on those ranges and it isn't so. They are averages yes, but not definitive. Depending on time of year, where you are at you may never see above 180 being fully warmed up, I know I don't in the winter time. Conversely I've seen between 205 and 215 fully warmed up in the summer time unloaded and there is nothing adversely going on. Various factors also play into that. None of which maybe something going wrong with the truck.
robinsonpowerstroke
15
04-22-2014 08:12 PM
