1966 Starter Problem
I believe I read one of Bill's post saying only one starter for the FE. That would be a 3 bolt, most of the others have 2 bolts.
Truck came with a 352, but a 390 surely could have been transplanted, starter is same for both.
Are the bolt holes lining up? Flip may be on to something you may have the wrong starter.
John
John
Yes the 3 bolts lined up.I'd like to blame starter,but not knowing what motor is or transmission is maybe wrong flexplate.Meaning maybe 352 with 289 flex plate?I can fix it by grinding nose cone and 1/8 inch off starter drive teeth.SO if there is only one 3 bolt starter and only 1 size flexplate I'll try another starter. thank you gentleman for your help.
C3OZ11002C .. Starter - 3 mounting holes (Motorcraft SA628)
Fits all: 1963/71 Passenger Car & 1965/76 F100/350 FE engines (352/360/390/406/410/427/428) with M/T & A/T.
C5AZ6375D .. A/T Flexplate / 184 tooth ring gear / 14 1/2" diameter / (16) 17/64" bolt holes on a 11 13/32" bolt circle.
Fits: 1965/67 F100/350 352 w/MX Cruise-O-Matic // 1968/76 F100/350 360/390 w/C6.
Fits: 1965/67 Galaxie/LTD/Thunderbird 352/390 w/FX & MX Cruise-O-Matic // 1966/71 Galaxie/LTD/Thunderbird/Fairlane/Torino/Comet/Montego/Mustang/Cougar 390 w/C6.
flipklos: I typed "flexplate" to clarify, but there's not one mention in any Ford Car or Truck parts catalog inre to "flexplate." Ford calls them flywheels whether for a M/T or A/T.
No 390 in a 1966 just 352
My 1966 F100 has this VIN #F10YR802876 which when I decode it means it
has a 360 motor. My son gave me the truck and he says the person that
owned it before him said it had a 360. If it was a transplanted motor would the VIN number be changed?
Just curious as everyone says there are no 360 motors in 1966 F100s
In 1966 the Y would indicate a 352 2V. The 360 was not available from Ford until 1968. If you have a 360 it would have to be a transplant. And, no, your VIN doesn't change if the engine is swapped out.
Ford FE engine - Wikipedia, the free encyclopedia
In 1968 the Y would indicate a 360 2V. You have to be in the right year to have the correct context for decoding.
360 = Y in VIN
Thanks for the info TA
When I look in the LMC truck catalogue under 1961-66 Vehicle Identification
under engine code there is no "Y" so I went over to the 1967-72 and found
a "Y" and with the info from the previous owners I figured that in San Jose,
California someone must have been ahead of time with a 360 and stuck it
in my truck. It has been confusing when ordering parts and not sure where
I am now.
I am now.
DrZoom
16
04-06-2016 11:42 AM
Bill Reich
11-10-2015 10:20 PM
jimpennycuff
06-15-2007 10:49 AM
