Hooking up my ISSPRO EV2 Gauges....
Hello everyone,
So I'm finally getting the chance to install my new EV2 gauges from Riffraff/Isspro as well as the GPR LED.
Now everything seems fairly straight forward except for my lack of experience with wiring...
Sooo my question(s) is where do I/you all get power for the gauges? Where do you tap into for the dimmer function? and how do you tap into the lines (cut and splice, butt connector, solder....)...?
I bought with the kit the potentiometer for "ease of install" and I like the options it has for lighting and such.... but where would said dimmer location be to hook this all up too? There are three options when it comes to dimmer control, and I was thinking of hooking it up such that they are controlled by the dimmer switch in the dash, and I can turn them down even further. Or should I do the second option where the lighting function is independent for from the dash lighting? (the third option is to have the gauge lighting completed independent of the dash lighting and controlled by the pot, this is easy but wondering about the other options) So where are these locations wires) in the headlight switch?
Thank you all for your help! Also any tips or tricks you might have for daisy chaining the gauges together is VERY appreciated.
-Jon
-Jon
Hello everyone,
-Jon
-Jon
Look at photos #31 and #32 of this link. That's how I got my power and lights hooked up.
Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
I followed these, and it was a piece a cake! Enjoy!!
