Isspro EV2 boost gauge
Old Mar 22, 2015 | 03:25 PM
Eaglescout94's Avatar
Eaglescout94
I installed my boost gauge along with the other 3 Isspro gauges I ordered and while the three work fine boost doesn't. If I have the running or headlights on the gauge doesn't work and it doesn't illuminate, the warning light just blinks, if the lights are off the gauge works like it should. Where should I start looking?
Old Mar 22, 2015 | 03:54 PM
Tugly's Avatar
Tugly
It sounds like a lifted ground to the gauge power. Look there.
Old Mar 22, 2015 | 04:04 PM
Eaglescout94
What do you mean by lifted ground?, the ground isn't fully seated... What am I supposed to be looking at in your picture?
Old Mar 22, 2015 | 07:04 PM
Tugly's Avatar
Tugly
The #3 black wire (close to the middle on any single gauge connector) is the gauge power ground, and the #6 black wire (far right on boost connector) is the sensor ground. Make sure the two ground wires are not swapped, and that they have solid connection.
It could be one of the other wires, but your symptoms sound more like a funky ground.
Old Mar 23, 2015 | 10:19 AM
Eaglescout94
All the wires are in the correct spots, they are all fully inserted( used the install tool and mini screw driver to check) and the gauge still doesn't light. It also makes a buzzing noise when the lights are turned on.
Old Mar 24, 2015 | 07:29 AM
Tugly's Avatar
Tugly
It could be a defective gauge, but the fact that it acts up with the lights on usually points to a wiring issue. Power to #1 and dash light voltage to #2?
Old Mar 24, 2015 | 04:48 PM
Eaglescout94
Somehow after looking at my wiring several times I missed that I did put the illumination wire in the ground slot and vise-versa. Now everything works fine. Thanks Tugly.
Old Mar 25, 2015 | 08:40 AM
Tugly's Avatar
Tugly
That's no worse than the time I put my underwear on backwards - and didn't discover my faux pas until I was standing at the urinal. If anybody else was in the room, they'd be wondering "What... he can't find it?"
OBSTommy17
Apr 24, 2019 10:44 PM
kupaa
Apr 30, 2011 08:20 PM
powerstroke1869
Ford Truck Parts for Sale
Mar 26, 2010 10:30 PM
CAT_man_963
Jul 25, 2006 09:39 AM
