Glowshift 3 in 1 gauge dimmer question
For those of you that have installed Glowshift's gauges, they don't recommend tying the 'Orange' dimmer wire into the dimmer wheel circuit.
NOTE: Do not connect the orange wire to a dimmer wheel. This will cause the gauge lighting to flicker. I'd like to know the location of the headlight wire that I need to tap into so the gauge will dim by design by 30% when the headlights activate either manually or automatically. Thanks in advance. g
