shifter bushings
I removed the pin from the shifter/collar housing...(w/the spring in it)...looking at the shifter there is a somewhat large bushing that goes around where the hole in the shifter is (that he spring goes through)...there was also a smaller skinny bushing that was on the tip that goes into the collar...it is broken...im just not sure it that little bushing cam from inside the collar or if it goes on the shifter handle?....thanks
I removed the pin from the shifter/collar housing...(w/the spring in it)...looking at the shifter there is a somewhat large bushing (7246) that goes around where the hole in the shifter is (that he spring goes through)...
there was also a smaller skinny bushing (7335) that was on the tip that goes into the collar...it is broken...im just not sure it that little bushing cam from inside the collar or if it goes on the shifter handle?....thanks
O1A7246B .. Insulator-Gear Shift Lever-2.04" long / Obsolete
B8S7246A .. Insulator-Gear Shift Lever-1" long / Obsolete
B8S7335A .. Gear Shift Lever Impact Sleeve / Obsolete
Measure the insulator your truck has, post the length, then I'll see who has it and the sleeve, then post what I find.
rockpile
22
07-09-2015 11:24 AM
walthehippie
09-16-2005 12:56 PM
