I-6 myth?
Glad to have you here.
Take a look at this link http://www.ford-trucks.com/forums/ar...-136-p-59.html
The FE engine and 300 straight 6 both use the same engine perches, only they need to be unbolted and moved to the forward mount holes.
You'll need the 300 engine, bellhousing and the engine side z-bar bracket. You would use your existing transmission.
The funky thing is adapting the existing exhaust or just building a new one.
The other funky thing is the radiator. The top hose is usually on the driver's side for the I-6, passenger side for FE engines. And reverse for the bottom hose. So either a new radiator will be needed or some creative use of piping to get the inlet/out to match.
Josh
Josh
As for the 360: a simple rebuild, RV cam and a 390 crank and rods would be the way to go for mild manners and "decent" mileage.
In my opinion, whatever engine you already have is the one I would pursue. If I had both engines and they both needed to be freshened up or rebuilt I would go with the FE since it seems you're truck has some steep gears (running some numbers it looks like around 3.9 to 4.10 gears depending on the tire size, I guessed 31" tires) and the FE will handle 3000 RPM better than the I-6.
If I had a second truck I would want to have a 300 in it for economy no doubt, but it's hard to justify cost when all that money can be used to buy gas in the first place.
Josh
Josh
Taking a 360 to 390 is just a matter of sourcing a 390 crank and rods, more power and better efficiency than a 360.
I have always driven mine on the highway, but back when I still drag raced I would install my 3.00 gears to keep the rpms down. I now have the 3.00 gears permanent and it wasn't unusual to go over 100 mph on I-70 to visit my family in Kansas. The only thing that slowed me down was gas stations.
For a 390, 2600-3000 RPMs is butter.
Josh
Josh
Josh
Josh
All 360s are the same.
The only FE engines with "4 bolt" mains, but really cross-bolted mains are 427 engines and a few 406 engines.
I would actually expect slightly better economy with a 600 CFM 4 barrel and 4 barrel intake. There are a couple factory 4 barrel intakes that are decent, but heavy and some nice aluminum ones.
Josh
Josh
the truck seems low geared, 2800 rpm @ 65 mph.
My '77 150 4x4 300-six does 3100 @ 60mph, with 31 x 9.50R-15LT tires, almost 3200 @ 60mph with the stock LT235R-15's (or as they said in '77, L78-15's). This is the way it's been since new.
14 mpg on regular gas all the way, though.
drection
I was headed in your direction and ended up gong with a 351W and a chevy Nv4500 for the overdrive. I was lucky enough to find a 79 3/4 ton 4x4 as a donor for the frame and 4x4 stuff. My 73 had a 360 and the 79 had a 351M. The 351W fit on the 351M perches.
Bought an adapter from Advanced adapters and mounted the NV4500. Just finished the frame and rebuilding the 60 rear and 44 front. Got the brakes and back on this morning.
I have the low mileage 360 or a 300 if you need them. Also the 351M/400 with c6 and np205.
A lot of what you do should depend on how you plan to use your truck. Mine will be mostly hi-way with some towing mostly hi-way towing. I wanted 4x4 for the bad weather and some off-road. I have 354 gears and plan to keep them.
Good luck and post some pics. I will put more of mine in my garage later this weekend.
Doug
Doug
95badbird
04-28-2005 04:50 PM
