2011 SD Mud Guards
Are they necessary? I look at it like this, imagine putting a hand full of sand in your underwear then running a marathon. Just a side note to anyone ordering these, there is a difference between a "flared fender" and a "fender flare". Keep this in mind when ordering, just because your fenders are flared doesn't mean you have fender flares. Make sense...good.
It's a little more work to apply the clear film that they provide, but let me ask you this......why do you think Husky provides the film with their fender flares? I'm sure it's not because they like putting extra stuff in the box.
I don't like sand in my britches cause it leads to a painful case of monkey-butt, and I don't like things rubbing on my paint because it leads to a painful case of Doh!
I used the film.
I used the film.
I got the Husky ones, went on very easy. The only drilling is through the plastic inside the wheel well. It just keeps everything looking neat and clean. The screws pull everything tight together so there is no gap, other then that no drilling into metal, means no rust. They look good too, and keep all the snow and mud off my running boards too.
Yes, I put the protective plastic on first. It will keep the metal from getting scratched from the flaps when dirt gets in between. It only took about 20 min to put everything on. The protective coating on all 4 first then the mud flaps.
