rotella ELC in my 6.0l?
I just ran out of my warranty like 5 day's ago,and i've herd that out ford gold could be are week point in our cooling system. I have a coolant filter already,and i'm thinking of trying rotella ELC.I was wording if any of you all have try it or are still use it and if so how is it working out so far. THANKS
Ford Gold coolant is the strong point of the cooling system, the weak point is the casting sand and debries, so still with the Gold coolant and your coolant filter, you should be good.
Actually Ford gold does not meet the BM1 standard that IH uses for there coolant.
Can you provide any proof of this claim? Why is it the strong point? Can you provide evidence of why the same coolant that is in the 4 cylinder Ford Focus should be in a Powerstroke diesel? Could it be that Ford gold coolant is sold at the Ford dealership? Why does Navistar use Texaco ELC coolant in this motor? Navistar designed this motor so I think maybe the coolant they use ( and don't make any money from) is the way to go. The sand and gel that is found in the coolant filters may be attributable to precipitate dropout and not necessarily just casting sand.
Im not a scientist, so technically no, i've always been told to run gold coolant so i will, it would be nice if someone had a comparison to Ford gold and texaco elc or whatever else. Ill stick with the Ford gold for now, unless i see proof of other brands working better.
I didnt know navistar used Texaco elc, sorry for being a coolant noob
There is quite a good technical discussion on this at TDS. Much of it is theory and opinion, but that is where learning starts IMO. I have been a staunch advocate of OEM fluids, but I am seriously considering the ELC coolant when my warranty runs out. Until then, I will frequently check the nitrite levels and flush the coolant every 40k miles (every 2 years). I believe that the flushes and the coolant filter will keep my system healthy. I will say that I was one of the group that found a TON of solids when I first installed the coolant filter. I know that my oil cooler is partially plugged due to the first 15k miles, but I monitor it and it is not too bad.
