352 oil capacity
Old 09-16-2012, 09:08 AM
Boss9F100's Avatar
Boss9F100
Boss9F100 is offline
1965/76 F100/350 FE's should use the horizontal oil filter adapter. 1965/71 FE Passenger Cars use the vertical oil filter adapter.
Using a vertical adapter on a truck: The filter will be inches from the engine crossmember, if the left motor mount (steel/rubber insulator) breaks, which is somewhat common, the filter will hit the crossmember, splitting it open. Not pleasant!
Original Auto-Lite/Motorcraft 'spin on' oil filter was FL-1. Today's it's Motorcraft FL-1A
I am with ND on this one. The manual clearly states approx 5 qts plus 1 qt with filter change. So proper level is over 5qts. My all original '65 has to have 6 qts to be at full mark! many different dipsticks and tubes have been used so its easy to be off if either has been changed.
ND, the vertical oil adapter was replaced with truck one because the filter WOULD NOT clear the frame. Not even close as it hangs into frame at least 1 1/4"
  #47
Old 09-16-2012, 11:22 AM
camperspecial65's Avatar
camperspecial65
camperspecial65 is offline
Wow...are some REALLY still debating this...
I have a 68 owners manual among my collection...and just for the heck of it I looked to see what it said about refill amounts/crankcase capacities..
For ALL gasoline engines in the F100-350 trucks EXCEPT the 240-6, the owners manual says the same thing...5 quart capacity, add 1 with filter change.. Page 57 for those interested...and one of my manuals happens to have a nice lil pen asterisk next to the footnote of add a quart with filter change.
- cs65
  #48
Old 09-16-2012, 02:10 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
NumberDummy did your '65 have a front or a rear sump pan? I know the rear sump pans hold more than front sumps (IDK how much). On my all original, never been apart 352, I put 6.5 quarts in (way over full) and it will be on add in 500 miles (the assemblers did a poor job at sealing the rear of the intake; oil literally runs out).
  #49
Old 09-16-2012, 02:52 PM
camperspecial65
Mine is a front sump as i recall...as to the oil flow..theres engines...among others...have a knack for pushing the front and/or real intake gaskets out...when they do get changed typically a generous wad of silicone is advised at the 4 corners...
- cs65
  #50
Old 09-16-2012, 06:44 PM
1972RedNeck
  #51
Old 12-20-2019, 05:59 PM
Rollbar's Avatar
Rollbar
Rollbar is offline
I noticed while changing the timing chain, that the oil pump p/u was 1/2 (little more) way covered with oil and I think I put 6qts in (been a while since I've been working on it).
  #52
Old 12-20-2019, 08:38 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Man, that poor 🐴 horse!
One thing I didn't see mentioned it may be somebody who installed six (6) quarts and started fogging the neighborhood has an engine with a lot of internal sludge buildup.
Neglected engines, engines that have never had an overhaul or rebuild, back in the days especially of leaded gasoline and dirt cheap re-refined paraffin motor oil etc etc would have an inch of heavy sludge buildup in the pan. That could easily explain why a particular engine won't take 6 quarts.
dh_meyer
2009 - 2014 F150
18
06-01-2023 03:38 PM
79flat
04-25-2017 07:42 PM
JimboNettles1973
21
03-31-2017 10:54 AM
mslopnick
15
09-30-2016 04:44 PM
pauleouellette
09-13-2015 10:46 PM
Quick Reply: 352 oil capacity
