5.8 motor ideas
I wouldn't think the power would be significantly different between a 393 and a 408
depending on how they were built. I do agree with being careful about how much
overbore you can safely do on a 351W. If I was going over .030 and was building it
for some power I would have it sonic checked.
You are right Conanski. I worded my post wrong. What I was trying to say was if I
was going bigger than .030 over I would consider having it sonic checked. Do you
feel that most any any 5.8 production block would safely take a .040 overbore? I have
always limited 289 and 302 blocks to .030 but have never tried more on a 351W.
It is possible to run Cleveland heads on a windsor block but it is not a direct swap. It takes a special intake and some modification to the head gasket. They used to have a write up on this in the Ford Racing parts catalog.
the edelbrocks are cast similar to the 2V cleavland head the flow about 200cfm and have 2.02 intake valves. plenty of bottom end, the 4V heads had something like a 2.19 intake and flowed about 300cfm. the only head to flow more was the police interceptor 460. stock obviously. they say the 2v heads made killer street heads the power band was nearly as flat as my first girlfriend...lol
#28
they have some port work done to them, i dont know how much as of yet. i'll know more in a couple days when we tear the motor apart. like i said the deal is insane and i really cant pass on them. i may end up selling them and get a set of afr's but i'll see what the machinist says about them. he did a hell of a job on my 390 in my highboy and i've seen his work rolling around the track here in town.
JDBeck23
11-12-2012 11:05 AM
TheMechanicalAnimal
03-29-2009 04:42 PM
Meilichios
01-09-2006 06:14 PM
vatainc
13
06-16-2002 09:21 PM
