How to tell the year of my motor??
Old 07-01-2010, 08:27 AM
wanta79's Avatar
wanta79
wanta79 is offline
My 79 F250 came stock with a 400 but one of the previous owners swapped in a 460. Is there any way to tell what year the motor is and maybe what vehicle it came from?
Thanks,
Mark
Old 07-01-2010, 08:43 AM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
With Fords there is no way to tell what year the motor is. You cannot go by casting numbers regardless of what people say!
The same casting numbers were used for years and on some engine types the same castings were used on several different displacements.
Same numbers were also used across several vehicle lines also.
Old 07-01-2010, 10:48 AM
bmarkline's Avatar
bmarkline
bmarkline is offline
Four digits, take for example the heads on my 460cid. "D0VE". The first letter, "D" stands for the decade it was designed in. C= 1960's, D= 1770's, E= 1980's, and so on. The second digit is a number. This designates the year within the decade it was designed for use, in this case, 0 (zero)= 1970. The third digit, stands for the type of vehicle the part was designed for, in this case "V" stands for Lincoln. And the forth letter stands for where the part goes on the vehicle, as in "E" for "Engine" so my heads were originally designed for use in a 1970 lincoln engine. Now thats not to say thats the only place they were used though. Like Mike oOoOoOoOoOoOoOoOoOoOoO said, once the parts were designed and available to be used, they ened up everywhere, and the only time the casting #s were changed was when a redesign or revision was made, and most of the time when a part was revised it received only a suffix added to the end after a dash. Alot of these parts had the exact same casting #'s for years on end.
Old 07-01-2010, 01:34 PM
RangerHaywood's Avatar
RangerHaywood
RangerHaywood is offline
Wow your 460 was built in the 1770's? I knew Ford was the first!
Old 07-01-2010, 01:58 PM
1977f250's Avatar
1977f250
1977f250 is offline
My 460 is a 1969 swaped in my 77 F250 4x4
Old 07-01-2010, 03:01 PM
bmarkline's Avatar
bmarkline
Haha yeah, you know what I meant. I'll just blame that typo on public schooling.
Old 07-01-2010, 07:56 PM
RangerHaywood
Haha yeah i blame everything on that!
79Ranger250
05-17-2014 10:28 PM
dekota79f100
15
11-16-2011 10:57 AM
FarmerBill
07-14-2010 10:07 AM
INKAHOOTZ
03-08-2009 08:19 AM
Strokerin
15
02-07-2006 12:15 PM
Quick Reply: How to tell the year of my motor??
