ignition problem
ignition problem
turn my key truck wont start on the starter selinoid i cross over and start it but the two little wires that go on the side i can put the one on the left but when i put the one on the right the starter stays ingadged
You have either a bad ignition switch or there is a problem in the wiring for the starter circuit.
The starter circuit has a constant 12V being fed to it from some source. You have to find out where it's comming from.
I would unplug the ignition switch and see if it still wants to turn over when you hook the wires to the solenoid back up. If it doesn't, I would say the switch is bad.
If it still wants to crank, the problem is in the starter circuit wiring past the ignition switch.
heavy_d
16
03-21-2014 12:21 AM
mestup
15
06-26-2006 08:27 AM
BlueTorpedo85
02-15-2004 08:06 PM
Crumm
31
11-21-2003 10:22 AM
