ignition problem
Old Jun 26, 2010 | 08:38 PM
silver9696's Avatar
silver9696
ignition problem
turn my key truck wont start on the starter selinoid i cross over and start it but the two little wires that go on the side i can put the one on the left but when i put the one on the right the starter stays ingadged
Old Jun 26, 2010 | 10:52 PM
mikeo0o0o0's Avatar
mikeo0o0o0
You have either a bad ignition switch or there is a problem in the wiring for the starter circuit.
The starter circuit has a constant 12V being fed to it from some source. You have to find out where it's comming from.
I would unplug the ignition switch and see if it still wants to turn over when you hook the wires to the solenoid back up. If it doesn't, I would say the switch is bad.
If it still wants to crank, the problem is in the starter circuit wiring past the ignition switch.
Old Jun 26, 2010 | 10:59 PM
montana_highboy's Avatar
montana_highboy
How about some punctuation, can't understand a single a word you said.
Old Jun 27, 2010 | 12:30 AM
mikeo0o0o0's Avatar
mikeo0o0o0
heavy_d
16
Mar 21, 2014 12:21 AM
Fifty-Fourd
Apr 27, 2011 07:47 AM
mestup
15
Jun 26, 2006 08:27 AM
BlueTorpedo85
Feb 15, 2004 08:06 PM
Crumm
31
Nov 21, 2003 10:22 AM
