I have np205 fitment questions
I am getting a t-case from a guy who has a 79 F150 Ranger. It is a 351M with an auto transmission. it has 2wd 4wd hi/lo so I assume its an np205 but it looks weird. Will this t-case fit on my 76 F100 with the 435 manual?
This is the donor truck
I cant imagine that pic helping any but that is the truck its coming out of.
Sounds like a Dana 21 T-Case. It's the same one that was in my 74 F100. I'm going to F250 running gear and a divorced NP205. Just make sure you find the correct adapter and it should be fine. The T-Case adapter is different for a auto and manual (so I have read).
EDIT - Something I just found that could be a big deal in this swap. You need to look at the bolt pattern for the adapter housing that goes between yout tranny and t-case.
Also, read this thread. It might bring to light some of the dificulties.
https://www.ford-trucks.com/forums/5...o-a-np205.html
There is nothing wrong with the factory one. I have bad bearings in my transmission and I just replaced my ring gear, resurfaced the flywheel, and put in a new clutch. Is there a 4 speed trans I can use with this transfer case? I will be spending a good $300 rebuilding my transmission. I could buy a transmission that will fit the 205 instead. I don't want to loose the granny gear. The reason I want this t-case is that it has 4wd low and my original t-case does not. This truck is just an off road toy. Can I get a 31 spline output shaft for my transmission? I am going to rebuild it anyway.
AK FORD GUY
24
08-03-2021 08:57 PM
TA455HO
03-18-2013 10:10 AM
pumpdriver20
02-09-2011 09:46 PM
1978f-150
05-12-2010 02:09 PM
