Divorced NP205 Crossmember
Old Jul 7, 2010 | 09:04 PM
AK FORD GUY's Avatar
AK FORD GUY
I am using a 79 F250 frame for my build that looks to have had a married T-Case in it before I got it. I plan to use a NP435 4-Speed and a Divorced NP205 T-Case, that I already have, for this build. I have had a hard time locating a crossmember for the divorced NP205, but have found a few for a NP203.
Can I use a crossmember for a NP203 to mount my NP205, or are they too different?
What other years of trucks crosmembers will work?
I did a bunch of searching and reading, but did not find my answers.
Thanks for any help.
Old Jul 9, 2010 | 01:14 PM
grinnergetter's Avatar
grinnergetter
I have one out of a 75 but I'm pretty sure your frame is wider. Your frame should get wider behind the cab. If you can use it let me know.
Grin
Old Jul 9, 2010 | 01:47 PM
AK FORD GUY
Grin
Are you in my area or in the Lower 48. I live in Alaska and the price to ship one of these would make it pretty expensive. I can make a custom crossmember if needed, I was just trying to avoid it if I could. Thanks for the offer though.
Old Jul 9, 2010 | 05:06 PM
AK FORD GUY
Well it looks like 75F350 came through again. Found a pic in another thread that showed thr original crossmember when he swapped in the NP205.
This is good news.
Old Jul 9, 2010 | 05:13 PM
grinnergetter
Indiana, let me know. Will need sand blasting/ or not but I'm pretty sure it is in good shape.
Old Jul 9, 2010 | 05:17 PM
grinnergetter
Hold on, after looking at 73f250's pic mine is going to be a bit different. Mine will not have the arch in it. Mine is pretty much straight across although it held a 205.
Sorry
Old Jul 9, 2010 | 05:48 PM
4wydnr's Avatar
4wydnr
Not to highjack but does the crossmember also double as the cab mount?
Old Jul 9, 2010 | 09:48 PM
grinnergetter
Yes, on mine 73 and 75
Old Jul 9, 2010 | 10:41 PM
fordsrgrt's Avatar
fordsrgrt
crossmember for divorced 203 and 205 are the same,its the brackets that attach it to the crossmember that are different
Old Jul 9, 2010 | 11:25 PM
AK FORD GUY
Thanks for confirming it for me. It makes my search locally a lot easier. I am trying to locate a parts truck that already has the cab removed. Those rivets are a pain when you can't get at them.
Old Jul 11, 2010 | 08:23 PM
grinnergetter
Was working on the truck this morning and realized my mistake. I will no longer speak unless I know!!! what I'm talking about.
I probably wont be speaking much.
Old Jul 11, 2010 | 11:01 PM
AK FORD GUY
No sweat man. I think we are all here to learn and sometimes be able to lend a hand when we can. I am definately no exception. This is my first major 4x4 build and certianly the first time I have played mix and match on drivetrain parts. I am slowly getting parts together and should be close to jumping into it in about six weeks. Thanks for the thought and trying to help.
Old Aug 3, 2021 | 06:42 AM
Grendel's Avatar
Grendel
Thrread necro, sorry.
I am looking for these as well.
We built a skid mount for it, but don't want to reinvent the wheel if something already exists.
Old Aug 3, 2021 | 11:33 AM
redroad's Avatar
redroad
I'm not clear if your looking for the whole metal plate or what. This kit includes (4) upper and (4) lower insulators plus metal washers and comes in either red or black.
Old Aug 3, 2021 | 11:40 AM
Grendel's Avatar
Grendel
Looking for the cross members.
I have all the other stuff.
