1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-19-2014, 06:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
One headlight bright, one dim.
Old 05-19-2010, 08:17 PM
FarmingFord's Avatar
FarmingFord
FarmingFord is offline
Hey everyone
This has been a problem for awhile, my pass. side headlight has gotten really dim and as a result the driver headlight has gotten really bright. I cleaned the connector up as it had some white corrosion on it but it didnt seem to help. I can move it sometimes and it will come back bright but it doesnt last long. So the question is can I do anything with what I have or do I need a new connector or pigtail?
Thanks
Drew
Old 05-19-2010, 08:54 PM
11Bravo's Avatar
11Bravo
11Bravo is offline
Have same thing going on with the '03 250 I just bought, I was going to buy some new bulbs and see if it was something as simple as that...maybe it's a different problem now seeing this.
Old 05-19-2010, 09:02 PM
scottzj's Avatar
scottzj
scottzj is offline
Hangin 10 bra
Try these steps below IF you have already attempted to put new bulbs or switch bulbs on each side. This will let you know if its the connectors or the wiring corrosion.
1. Attach a test light lead to good ground source (test light)
2. Go to rear of the headlight, you may have to remove the headlight or locate the wiring harness that feeds the headlight.
3. Turn the headlights to the on position, regular mode, not high beam (do not start the engine). Using the test light probe the headlight electrical connector. Two out of three terminals on the connector will cause the test light to illuminate.
4. Remove the electrical connector from the headlight. With the headlights still "on" test the electrical connector, one of the two that had power will still have power. The terminal that had power before the headlight connector was removed and now does not is the problem. This wire/connection is the "ground" circuit for the headlight.
5. This ground completes the electrical circuit. The reason the headlight is dim is because the full voltage cannot be delivered to the headlight filament. Clean or reconnect the ground circuit wire to a new ground source and recheck headlight operation.
Old 05-19-2010, 09:09 PM
FarmingFord
Yeah I thought the same thing thats why I tried swapping them, but of course nothings that simple. haha
Old 05-19-2010, 09:27 PM
11Bravo's Avatar
11Bravo
11Bravo is offline
Will try this tomorrow, thanks for the post.
Old 05-19-2010, 10:14 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Yup, check those grounds, especially if the high-beam acts the same way.
Pop
Old 05-19-2010, 10:21 PM
11Bravo's Avatar
11Bravo
11Bravo is offline
Just found this post through doing some searching...
https://www.ford-trucks.com/forums/9...em-solved.html
Old 12-10-2014, 10:17 PM
Mr Zippy's Avatar
Mr Zippy
Mr Zippy is offline
Dim headlight fix, alternator, battery, ground 2003 Ford Escape
2003 Ford Escape 200k miles, a new headlight relay fixed the issue but read the details for Ford Escape electrical issues
I have a 2003 ford escape with 200k and recently had to replace the alternator as the batter light was on constanltly but it never died. After the alternator one light was dim after driving 300 miles. So I figured it was the battery as it appeared to be charging but low voltage while running 13.6 volts. So I put in a new battery and the charge dropped to 12.1 volts. No this does not make sense. So I pulled the alternator, 2 hour job on an escape and brought it to Autozone to be tested. It tested bad so I put in a new one and also added a ground between the battery ground and the block. The headlight was still dim until I put in a new headlight relay.
My guess is that the BAD battery and a bad ground killed 2 alternators and the headlight relay. First issues I had had in 200k so no complaints.
One thing I found while researching is the ability to turn your mile counter into a volt meter. Put the key in and turn it so the truck has power but do not start. hold down the mileage counter reset until it beeps twice. and a word appears. Let go of the button and start the truck. press the button like 20 times until BAT appears. it is now a voltmeter until you shut it off. you can also set it to tach and a bunch of other test options.
Enjoy!
krmoore77
1997 - 2003 F150
12-27-2020 08:24 PM
Cory Barrow
03-13-2017 01:16 PM
troverman
2017+ Super Duty
01-10-2017 07:47 PM
janschutz
08-26-2015 03:05 PM
Glenn Thomas
07-10-2015 08:24 AM
Quick Reply: One headlight bright, one dim.
