1978 - 1996 Big Bronco
power locks
Old 05-06-2010, 07:30 PM
gjnicholas's Avatar
gjnicholas
gjnicholas is offline
Question power locks
I have a 95 bronco with power locks that are not working right. if you lock the doors manualy then hit the remote the pasanger door un locks only if you hit the lock button the drivers door will unlock and pasanger door will lock nothing works from door switches but you can hear a relay clicking narrowed it down to a black box under the dash anyone else delt with anything like it
thanks in advanced
Old 05-07-2010, 12:06 AM
greystreak92's Avatar
greystreak92
greystreak92 is offline
Check the condition of the ground to both doors. The power feed to the door locks goes through the passenger side door first, then across to the driver's door.
Old 05-07-2010, 09:03 AM
gjnicholas's Avatar
gjnicholas
will try that thanks
Old 05-07-2010, 08:53 PM
ottawaguy's Avatar
ottawaguy
ottawaguy is offline
If you google " sluggish power door locks" ....you will find the fix for the failing ford door locks.
I did mine in about an hour and they work perfectly now. A lot easier than I thought it would be.
Hope this helps.
Fordtough2006
02-24-2016 01:07 PM
Roc53ky
1999 to 2016 Super Duty
08-08-2015 06:29 PM
99cummins
12-18-2013 09:45 AM
mwvdub
1966 - 1977 Early Broncos
20
02-05-2012 10:50 AM
jonboy88
20
06-12-2006 03:35 PM
Quick Reply: power locks
