easy way to lift 89 F250
Old 05-03-2010, 11:54 AM
Blade79's Avatar
Blade79
Blade79 is offline
I just purchased an 89 F250. I am just looking to use it as my toy. Hauling, hunting, play. I want to lift it but am not sure what would be they best way. it has stright front axle and leafs up front. Any suggestions?
Old 05-03-2010, 12:32 PM
andym's Avatar
andym
andym is offline
If it has a solid front axle then it's not stock. Someone swapped it in there. The first thing is to figure out what axle and how it was done. If there was any custom work done then the lift might have to be custom as well.
Old 05-04-2010, 08:59 AM
Blade79's Avatar
Blade79
Blade79 is offline
Your right it is not a solid front axle. Sorry about that I am new to this.
Old 05-04-2010, 10:17 AM
Conanski's Avatar
Conanski
Conanski is offline
But it still has leafs in front so adding a leaf is the easy way to lift it.
Old 05-04-2010, 10:19 AM
andym's Avatar
andym
andym is offline
Suspension lifts are better than body lifts for a lot of reasons, so if you're going to lift it do it the right way. How big of a lift do you want? What size tire are you going to run? Have you thought about gears?
There are lots of options to consider. You really need to do your research and decide what will fit your needs best. Do a search, there is a ton of information on these forums.
Old 05-04-2010, 03:11 PM
Blue Rebel's Avatar
Blue Rebel
Blue Rebel is offline
4" suspension lift, $600:
Old 10-31-2011, 12:34 PM
Tkholloman's Avatar
Tkholloman
Tkholloman is offline
F250 leveling kit
Ok I have a question I have a 2000 f250 rwd and I put the 2" leveling kit in the front. But iv been looking around and I found a 2" rear spacer to lift the backend of the truck but that will make it unlevel again so could I make a 4 in block for the front under the spring with a shock exstintion drop? Or would thAt be unstable in the front? Or do you think it will work?
Old 10-31-2011, 01:12 PM
andym's Avatar
andym
andym is offline
NEVER put lift blocks under the front springs.
Old 10-31-2011, 01:43 PM
Tkholloman's Avatar
Tkholloman
But that's where the 2" leveling block went was under the front coil
spring?
Old 10-31-2011, 03:23 PM
andym's Avatar
andym
andym is offline
Ok, I just realized a couple things:
- this wasn't your thread
- you're talking about a 2000 F-250
- this is the '87 to '96 forum
- your truck is 2wd
- so it has front coils
I am not real familiar with how your truck's front suspension is set up, but in general, when you start lifting 4", you need to start thinking about a dropped pitman arm, dropped sway bar links, extended brake lines, and possibly radius arm drop brackets.
You should start a thread in the correct forum to get the best responses.
colton haws
1978 - 1996 Big Bronco
02-11-2017 11:59 PM
rally68
03-26-2016 12:35 AM
SCRebel
22
06-20-2012 08:09 PM
Royson12
19
09-05-2010 01:17 PM
grams72
08-12-2010 09:28 PM
Quick Reply: easy way to lift 89 F250
