How much lift from f250 rear leaf springs?
For all those who know I have 3" of lift at the rear, but 8" at the front.(79 6" lift springs, 89 coil buckets) And I want to remedy that. I can get F250 springs from the local junk yard way way cheaper than a shackle flip kit. I also bought 5" lift blocks for the rear.
How much lift will the f250 springs provide? How much will it stiffer will the ride be?
It would be kinda nice to do the f250 springs and 3" blocks so I don't have as much axle warp.
I am wanting to get to at least 6" on lift in the rear.
Thanks fellers!
Thanks fellers!
Thanks fellers!
Thanks fellers!
F250 springs would get you maybe 1" tops if that.
If you want 6" in the back, the cheapest way is to do a shackle flip.
My drivers side spring is very weak, can't even fill up the side tank without it leaning dramatically, So new springs are a must. Bronco graveyard list new stock f250 springs in different arches for use with or without the factory blocks. I feel for my use that if these springs will lift my truck 2 inches then I can remove the factory block and stiffen a very soft rear suspension at the same time. Any input on my idea would be very appreciated
That's what I want, just want to keep it fairly level, I have leveling coils now and it's bout 2 higher in the front. I feet that if f250 coils lift the back 3 inches by themselves and I removed the block, It would set exactly how I want it to. The only question is which f250 leaf pack should be used, The heavy duty f-250 pack or the light duty f-250?
Yes the 92 sits like a cat in heat...
All measurements were taken at the rear wheel well directly above the center of the axle.
