shutter on take off
Old 04-15-2010, 12:27 PM
n20's Avatar
n20
n20 is offline
shutter on take off
Over the weekend i took the driveline off and greased the slip yoke, it was clunking pretty bad starting and stopping. Now its smooth as glass other than i can feel a slight shutter or rumble right as i start accelerating from a stop that i didn't notice before. Lasts just a second or two and then its gone and no problems at all after that intitial start. Any Ideas?
Old 04-15-2010, 03:47 PM
Robert6401's Avatar
Robert6401
Robert6401 is offline
Do you have any sort of lift or leveling kit on the truck? It sounds like the driveline may be out of alignment just a touch. This is pretty common when the rear of the truck is raised. The fix is to use shims to realign, but don't ask me how to do it because I need to do it also and don't know how.
Old 04-15-2010, 03:51 PM
n20's Avatar
n20
n20 is offline
no lift, just leveled. i'm wondering if when i took the driveline off to grease the slip yoke i didn't get it back on the same way it came off. not sure if that'd cause it
Old 04-15-2010, 04:28 PM
CPUNeck's Avatar
CPUNeck
CPUNeck is offline
That should only show up at speed (drive line speed.) Did you inspect your U-joints? Recently I was performing some maintenance on the rear end, and while the drive shaft was out, I just popped one of the caps off to take a look. What do ya know, ONE of the needle bearings was broken and 1/2 of it was missing. "Spun" fine, no binding or anything, but dead lined. New U-joint, and now the truck rides "smoother" hard to explain, but the joint was transmitting some vibration through the drive line that I had not attributed to drive line problems.
Old 04-15-2010, 04:37 PM
n20's Avatar
n20
n20 is offline
yeah after the intitial take off it rides smooth. i checked the ujoints while i was under there and they all seemed to be ok. I didn't see/feel anything out of the ordinary.
Old 04-16-2010, 07:23 AM
03_PSD's Avatar
03_PSD
03_PSD is offline
When's the last time you changed your rear diff fluid?
Old 04-16-2010, 09:10 AM
n20's Avatar
n20
n20 is offline
just last year. Used the Redline Synthetic brand of gear oil, and i believe that has the LS additive in it. I never noticed it before, just after i greased the slip yoke
Old 04-17-2010, 12:48 AM
ztodd377's Avatar
ztodd377
ztodd377 is offline
If for some reason you do need to shim the driveline, crawl under the truck and there's a support where the 2 piece driveshaft joins. 2 bolts, an 1/8 in pice of steel or two and you're good to go.
Old 04-17-2010, 01:32 AM
N V US Lawn Care's Avatar
N V US Lawn Care
N V US Lawn Care is offline
this may be a sucky reply, but here goes anyway...pull the diff cover and check the teeth, there may be one broke in there, and maybe that broken piece of metal is floating around in the fluid, and at start off, it starts working it's way through the rest of the teeth...i dunno...
maybe hit the usual suspects before you do this...also, while you're in the rear end, check the side to side "lash" of the punkin'...there's shims in there too that could work themselves out over time, or wear out...
Old 06-11-2010, 10:12 AM
Robert6401's Avatar
Robert6401
Any advice on where to get the 1/8 in pieces of steel? I need to do this bad.
Old 06-11-2010, 10:28 AM
megawatt00's Avatar
megawatt00
megawatt00 is offline
A piece of flat stock that you drill will work on this Bob. Any hardware store should have it if there are no steel supply places around you.
Old 06-11-2010, 12:25 PM
Robert6401's Avatar
Robert6401
Thanks Jim!
Old 06-18-2010, 11:45 AM
ztodd377's Avatar
ztodd377
ztodd377 is offline
Bob,
Sorry I didn't reply sooner. I've been out of the country in Bangladesh. Jim said exactly what I did though. Got some flat stock, drilled it and installed it.
Old 06-18-2010, 01:37 PM
HH60FE's Avatar
HH60FE
HH60FE is offline
Mine does the same thing. Lasts for about 20 feet. I don't worry about it, amybe I should.
Chris Anchor
2009 - 2014 F150
12-30-2013 08:34 AM
montey2005
1999 to 2016 Super Duty
08-15-2012 09:23 PM
ZChavira
2009 - 2014 F150
10-04-2011 11:00 PM
john63
03-25-2006 03:38 PM
oxbow
04-09-2001 11:34 AM
Quick Reply: shutter on take off
