Remove Computer
Old 04-09-2010, 08:02 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
Remove Computer
For my 92 F150, 4x4, 351w, can someone tell me where the computer is located and just exactly how to get it out?
I remember reading that it isn't located in a friendly spot and is a little tricky to remove. Not even sure where to start looking.
Thanks.
Old 04-09-2010, 08:12 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
open hood, it is below brake booster a little towards fender.
a search would really get 100s of hits and much info for you.
Old 04-09-2010, 08:17 PM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
Just out of curiosity, why are you pulling the computer? Swapping it out with a different one or what?
Old 04-09-2010, 09:16 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
Yes, the kit comes with a new computer.
Old 04-10-2010, 03:36 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
Remove the inner fender liner on the driver's side. Once that is out remove the EEC connector. If I recall there is another small metal bracket to remove then the computer slides out. Takes about 15 minutes.
Old 04-10-2010, 10:11 AM
quicklook2's Avatar
quicklook2
no need to remove inner fender completely.
only the side computer is on.
disconnect battery.
Old 04-18-2010, 01:59 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
what am I missing with this? I have removed the connector to the computer and the two nuts on the side of the firewall but it seems that the way to get the computer out is to push it back into the hold and get it from inside somehow?
When I removed inner fender liner that doesn't seem to get me what I need unless I am supposed to pull the computer out towards the front of the truck.
Old 04-18-2010, 02:32 PM
quicklook2's Avatar
quicklook2
you pull it out towards front of truck.
it should slide out easily.
Old 04-18-2010, 05:41 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
got it out, thx
Old 04-18-2010, 06:26 PM
quicklook2's Avatar
quicklook2
great.
SOLOLUCKY
1999 to 2016 Super Duty
03-05-2015 06:58 AM
REDDOG_0_0_7
13
10-14-2013 09:45 AM
dean302
07-22-2011 05:56 PM
Raxid
Engine Swaps
06-27-2009 04:27 PM
Fallguy2004
Computer Chips & Tuners
07-25-2006 10:30 AM
Quick Reply: Remove Computer
