Sponsored by: Real Truck
computer module location/keyless entry code
Old Feb 8, 2009 | 10:15 PM
REDDOG_0_0_7's Avatar
REDDOG_0_0_7
I am looking for location of the computer module on my 2008 F350 6.4 liter diesel
Old Feb 9, 2009 | 02:49 PM
Beerstalker's Avatar
Beerstalker
If you bought the truck new it should have come with a little card in the glove box with the Owner's Guide that has the code on it. Otherwise I would start by looking behind the radio up on the firewall as that is where it is on the earlier SD.
Old Feb 9, 2009 | 05:49 PM
shorebird's Avatar
shorebird
Open your glove box then carefully bend the corners where the stops are to release them. The box should now hinge down out of the way. The BSM back in there and the code is on it.
Old Mar 19, 2009 | 09:46 PM
DAVE67FD's Avatar
DAVE67FD
Sorry wrong posting
Old Mar 19, 2009 | 09:57 PM
Dually TAS's Avatar
Dually TAS
Mine was behind the drivers glove box all the way in the back behind some white insulation. The code was in bold numbers and very easy to find.
Old May 5, 2011 | 02:50 PM
tankkillr's Avatar
tankkillr
do you by chance have a pic of the box and what the code looks like on it??? im not sure what im looking for or at and am finding numbers all over the place?? thanks
Old May 6, 2011 | 02:55 PM
tankkillr's Avatar
tankkillr
Exclamation
did you ever find your code?? im looking for mine and was wonderring where you found yours and what i looked like cuz im lost!
Old Jun 13, 2011 | 10:47 PM
Eskinny's Avatar
Eskinny
2009 F350 door code location
I have been looking for 2 days for the factory code for my 2009 F350, I have removed the panel below the steering column and searched with a light and taken a whole bunch of pictures with my iPhone where I could not look. I have looked behind the glovebox and searched all over the Internet with no luck so far. I would be very grateful to anyone who can offer specific info on how to find this code.
Old Jun 14, 2011 | 01:03 AM
tankkillr's Avatar
tankkillr
im in the same boat as you my friend......looked all over the net and took the pics w/phone etc and still no luck.....im dying to find out where its at myself and what it actually looks like!! if you find out where it is please, please let me know too!!
Old Oct 13, 2011 | 07:15 PM
jjallen's Avatar
jjallen
I Finally found it
Ok it is located on the back side of the fuse panel or otherwise known as SJB (SMART JUNCTION BOX) on the passenger side kick panel. Firstremove the entry trim piece on the passneger side that says "SUPERDUTY" then remove the fuse panel door followed by the remaining trim piece. There is two Bolts on the fuse panel. remove then and it is on the bottom left corner of the bigger sticker.
Old Feb 15, 2012 | 05:46 PM
C-172-42quebec's Avatar
C-172-42quebec
5 digit code location
My USED 2008 SD dually 4x4 (manufactured early 2008) with NO MANUAL! had it located on pass. side kick panel, fuse block, back side.
It was on the bar code lower rt. bottom as you read the tag. 2 - 7mm screws were removed to pull block off the sidewall. You do have to remove the super duty step panel, rubber trim, and triangle fuse panel, then pull trim piece to the rear and you'll have the fuse block exposed. The #'s are SUPER SMALL! I pulled the tag off, and stuck it in the owners manual & used a sharpe to write it on the fuse panel door trim piece as well. Saved me an hour at the "Stealership" who wanted an hour worth of labor to read it from the computer. Please try this first and save some time and money!!!
Old Apr 30, 2012 | 12:59 PM
2008 BlueOx's Avatar
2008 BlueOx
Thanks All!!
Thanks guys, You all save me $80. I pulled the fuse box behind the passenger side kickwall panel and found my code too. My truck is also a 2008 F350 Dually 4x4, and its code was in very small lettering on the right top corner of the larger tag.
Old Sep 26, 2013 | 03:51 PM
Nineballrnnr's Avatar
Nineballrnnr
Thanks! My 2008 F250's code is in the same spot.
Old Oct 14, 2013 | 09:45 AM
shinerbockdoc's Avatar
shinerbockdoc
Trailering
EXACT PRECISION -- THANKS!!!! 5 digit code location
Man, thanks alot!!!! Your description is so precise, it is unreal. I just helped a buddy get the code for his 2008 F250 CC 4x4 KR, identical to mine, except for the year.
He is happy and owes me a cold one now!
derek4343
2009 - 2014 F150
Dec 29, 2013 10:51 PM
kabur66
6.7L Power Stroke Diesel
Jan 16, 2011 04:05 PM
kabur66
Jan 12, 2011 02:01 PM
stubnessa
Jul 9, 2010 10:14 AM
detrant
New Member Introductions
Feb 29, 2008 02:10 PM
